Polygon not showing up
1838
6
04-21-2014 07:08 PM
DiptiSheth
Following is my code:
function LoadEsriTrees() {
var divEsriMap = $mover.find('div#mapDiv').attr('id');
require(
["esri/map", "esri/layers/GraphicsLayer", "dojo/_base/array", "esri/geometry/Point", "esri/symbols/SimpleMarkerSymbol", "dojo/_base/Color", "esri/graphic", "esri/InfoTemplate",
"esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/ImageParameters"],
function (Map, GraphicsLayer, array, Point, SimpleMarkerSymbol, Color, Graphic, InfoTemplate, ArcGISDynamicMapServiceLayer, ImageParameters) {
map = new Map(divEsriMap, {
center: [174.605, -37.119],
zoom: 15
//var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer", { id: 'basemap' });
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer", { id: 'basemap' });
map.addLayer(basemap);
//show polygon
dojo.connect(map, 'onLoad', function () {
// var myPolygon = new esri.geometry.Polygon(new esri.SpatialReference({ wkid: 4326 }));
var myPolygon = new esri.geometry.Polygon([[174.605111568859, -37.119413675388707], [174.6051123299834, -37.119449718193458], [174.60515905129122, -37.119530204987136], [174.60540067619004, -37.119779304335452], [174.60554255499551, -37.120101860545844], [174.60568043759687, -37.120235191897571], [174.60572696965184, -37.1203066677341], [174.60572849253467, -37.120378753310746], [174.60570674933629, -37.120415100973361], [174.60560757225889, -37.120515590528086], [174.60554177129595, -37.120597601350227], [174.60549026791193, -37.120823630882519], [174.6054873903158, -37.121220253972716], [174.6055119446122, -37.122382633739591], [174.60513274122792, -37.119350295725816], [174.605111568859, -37.119413675388707]]);
// map is in web mercator so transform the geometry
// var poly_wm = esri.geometry.geographicToWebMercator(myPolygon);
// var symbol = new esri.symbol.SimpleFillSymbol().setStyle(esri.symbol.SimpleFillSymbol.STYLE_SOLID);
var symbol = new esri.symbol.SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]) );
// polygonGraphic = new esri.Graphic(poly_wm, symbol);
polygonGraphic = new esri.Graphic(myPolygon, symbol);
map.graphics.add(polygonGraphic);
Can any one please help me to locate polygon on the map? I don't know..where I'm getting wrong, its not showing up polygon on the map.
Dipti Sheth
JakeSkinner
Esri Esteemed Contributor
Hi Dipti,
Take a look at this example.  This should get you going in the right direction.
<!DOCTYPE html>
<html>
<head>
  <title>Example</title>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
  <style>
    html, body, #mapDiv{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="http://js.arcgis.com/3.8/"></script>
  <script>
    var map;
    require([
        "esri/map",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleLineSymbol",
        "dojo/_base/Color",
        "esri/graphic",
        "esri/geometry/Polygon",
        "dojo/on",
        "dojo/dom",
        "dojo/domReady!"
    function(
        Map, SimpleFillSymbol, SimpleLineSymbol, Color,
        Graphic, Polygon,
        on, dom
      map = new Map("mapDiv", {
        center: [174.605369, -37.120276],
        zoom: 15,
        basemap: "streets"
      on(map, "load", addGraphic);
      var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
        new Color([255,0,0]), 2),new Color([255,255,0,0.25])
      function addGraphic(){
            var singleRingPolygon = new Polygon([[174.605111568859, -37.119413675388707], [174.6051123299834, -37.119449718193458], [174.60515905129122, -37.119530204987136], [174.60540067619004, -37.119779304335452], [174.60554255499551, -37.120101860545844], [174.60568043759687, -37.120235191897571], [174.60572696965184, -37.1203066677341], [174.60572849253467, -37.120378753310746], [174.60570674933629, -37.120415100973361], [174.60560757225889, -37.120515590528086], [174.60554177129595, -37.120597601350227], [174.60549026791193, -37.120823630882519], [174.6054873903158, -37.121220253972716], [174.6055119446122, -37.122382633739591], [174.60513274122792, -37.119350295725816], [174.605111568859, -37.119413675388707]]);
            var gra = new Graphic(singleRingPolygon, sfs);
            map.graphics.add(gra);
  </script>
</head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
DiptiSheth
Hi Dipti,
<!DOCTYPE html>
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script>
    var map;
    require([
        "esri/map",
        "dojo/_base/Color",
        "esri/graphic",
        "dojo/on",
        "dojo/dom",
        "dojo/domReady!"
    function(
        Graphic, Polygon,
        on, dom
        zoom: 15,
        basemap: "streets"
  </script>
</head>
</body>
</html>
First of all really sorry for my late response.
Thanks for your code..it really shows up polygon. But..next step is that this data comes from db, so when I store it in array or string and pass it to polygon as follows:
var singleRingPolygon = new Polygon(thisLocs.toString());
it again doesn't show up anything.
Please have a look at this and let me know...in which format coordinated data should be passed from db to show up polygon.
Thanks a lot,
Dipti Sheth
JakeSkinner
You will need to pass the coordinates as an array.  See the following link.
Create a new polygon by providing an array of geographic coordinate  pairs. For a single ring polygon specify an array of coordinate pairs.  For a multi-ring polygon specify an array of array coordinate pairs.
DiptiSheth
I get coordinates from db and format that data it in the following form:
If I hardcode this value as:
it works well and shows polygon.
But..how to convert it to array...I tried many things...but still no positive result. I created array, pushed all values into array and then passed it to create polygon...still of no help.
Please guide me in more detail.
Dipti Sheth
MichaelVolz
Can you post all of your current code where you get the polygon data from a db?
DiptiSheth
following is my current code:
var $mover = $('#thingtypecontent');
        var polygonData = $mover.find('input#hdndata').val();
        var check1 = (polygonData.indexOf("POLYGON ((") !== -1);
        if (check1 == true)
            polygonData = polygonData.replace('POLYGON ((', '[');
        var check2 = (polygonData.indexOf("))") !== -1);
        if (check2 == true)
            polygonData = polygonData.replace('))', ']');
           polygonData = polygonData.replace(/,\s+/g, '],[');
        //create polygon data
        var coords = new Array();
        var allLocs = new Array();
        var anchorLat = null;
        var anchorLon = null;
        coords = polygonData.split(" ");
        var thisLocs = new Array();
        var anchorCoord = null;
        if ((coords.length / 2) % 2) {
            anchorCoord = coords.length / 2 - 1;
        else {
            anchorCoord = coords.length / 2;
        for (k = 0; k <= coords.length - 1; k = k + 2) {
           var thisLoc = new esri.geometry.Point(coords, coords[k + 1]);
                thisLocs.push(thisLoc);
                allLocs.push(thisLoc);
            if (k == anchorCoord) {
                anchorLat = coords[k + 1];
                anchorLon = coords;
    var map;
    require([
        "esri/map",
        "dojo/_base/Color",
        "esri/graphic",
        "dojo/on",
        "dojo/dom",
        "dojo/domReady!"
    function (
        Graphic, Polygon,
        on, dom
            zoom: 15,
            basemap: "streets"
        function addGraphic() {
            //            var singleRingPolygon = new Polygon([[174.605111568859, -37.119413675388707], [174.6051123299834, -37.119449718193458], [174.60515905129122, -37.119530204987136], [174.60540067619004, -37.119779304335452], [174.60554255499551, -37.120101860545844], [174.60568043759687, -37.120235191897571], [174.60572696965184, -37.1203066677341], [174.60572849253467, -37.120378753310746], [174.60570674933629, -37.120415100973361], [174.60560757225889, -37.120515590528086], [174.60554177129595, -37.120597601350227], [174.60549026791193, -37.120823630882519], [174.6054873903158, -37.121220253972716], [174.6055119446122, -37.122382633739591], [174.60513274122792, -37.119350295725816], [174.605111568859, -37.119413675388707]]);
             var singleRingPolygon = new Polygon(thisLocs);
