polygon.contains and polygon.getExtent()?
2982
03-09-2018 11:47 AM
ShaningYu
Honored Contributor
I created a polygon from ar2D.
var polygon_ = new esri.geometry.Polygon({
  "rings": ar2D,
  "spatialReference": {
  "wkid": 102100
var extent = polygon_.getExtent();
console.log("polygonExtent", extent);
var bContains = polygon_.contains(new esri.geometry.Point( ar2D[0] ));
However, the Results show:
the values of extent.xmax,extent.xmin,extent.ymax,extent.ymin are NaN
bContains = false
Unknwon why?  Thanks if you can help.
Tags (1)
JohnGrayson
Esri Alum
If ar2D[0] represents a point, then it wouldn't make sense to use ar2D as the 'rings' of a polygon. Considering that the extent coordinates are NaN, my guess is that ar2D needs to be wrapped up in an array like so:
"rings": [ar2D],
"wkid": 102100
...but just guessing as we have no idea what ar2D is...
RobertScheitlin__GISP
Shaning,
  Do your points in your array have a spatial reference assigned?
DanPatterson_Retired
Vince Angelo‌ asked a similar question about one of Shaning's other posts with no response yet
https://community.esri.com/thread/211013-polygoncontans-point-returns-false
JohnGrayson
Esri Alum
"rings": [ar2D],
"wkid": 102100
ShaningYu
Honored Contributor
Revised the code as
var ar2D = new Array();
for (var j = 0; j < p_.length; j++) {
   var ar1D = [p_[0], p_[1]];
   ar2D.push(ar1D);
} var polygon = new esri.geometry.Polygon(new esri.SpatialReference( { wkid: 102100 } ) );
polygon.addRing( ar2D );
var pt = new esri.geometry.Point(ar2D[0], new esri.SpatialReference({ wkid: 102100 }));
Then  polygon.contains(pt)   returns true.
Thanks to Robert, Dan and John.
Shaning,
   Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
