Point popup hyperlink
1645
12-02-2019 09:34 AM
ScottWilson2
Hi, I have a map with multiple points, when i click on a point i get a pointInfoTemplate popup.  I'm experimenting with adding my own hyperlink into this popup.  So far, i've only been able to add the hyperlink into the title area which says 'click me'.  I would like to add the hyperlink below the header, somewhere in the content pane, is that possible?  If so, what could should i use?  I've copied the snippet below.
thanks
for each (var item in apiData.items) {
var x = item.geometry.x;
var y = item.geometry.y;
var point = new Point(x, y, spatial);
 var pointAttributes = { Location: "item.attributes.LOCATION", Type: "item.attributes.BinType" };
 var pointInfoTemplate = new InfoTemplate("item.attributes.LOCATION<br/><a class='clickMe' href='#' onclick='alert(item.geometry.x + \", \" + item.geometry.y);return false'>click me</a>");
 var pointGraphic = new Graphic(point, pictureSymbol, pointAttributes, pointInfoTemplate);
 map.graphics.add(pointGraphic);
Tags (1)
RobertScheitlin__GISP
Scott,
   In your code the only thing you are specifying in the InfoTemplate constructor is the title. That is why your link is appearing in the title.
If you add a second string parameter in the constructor then you will be specifying the templates actual content.
https://developers.arcgis.com/javascript/3/jsapi/infotemplate-amd.html#infotemplate2
Scott,
ScottWilson2
Thanks Robert, i've managed to get it working.
