picturemarkersymbol.angle property
1633
05-05-2017 10:20 AM
AndreaWeeg
I am trying to rotate some point graphics i have on a map as the map rotates (so they don't look upside down) i got it working by using the angle property but it seems like it rotates the graphic on its center instead of the offset i am passed to it, the graphic is a tear drop so as it rotates it ends up pointing to the wrong place....is there something else i need to set so it rotates according to the offset instead of its center?
KristianEkenes
I'm having a little trouble picturing what you're trying to accomplish. can you post a screenshot or gif to demonstrate the expected behavior and what you're seeing?
