overview window always auto-centres the rectangle. Is this optional?
790
02-01-2012 01:15 PM
StephenLead
Honored Contributor
See the sample overview window map - when panning in the main map, the overview window rectangle re-centres within on the overview map, which pans to accommodate this, after each map extent change.
Is it possible to disable this, and firmly fix the overview map's extent? This would mean that the overview rectangle moved around within a fixed overview map, which itself didn't pan.
I'm assuming that the answer is no, and that I'll need to create two separate maps and link them manually - but I thought I'd check first to save time.
Steve
derekswingley1
Sorry Steve, don't think that's possible out of the box.
