Out of box Measurement Tool Error
1411
02-24-2014 07:26 AM
VikramS
Hello,
When I am trying to calculate the area using the out of the box Measurement tool . It is failing when the geometry crosses itself like below . Can anyone tell me whats the work around to solve it . If not , then how can I avoid the exception
[ATTACH=CONFIG]31708[/ATTACH]
JakeSkinner
Esri Esteemed Contributor
Hi Vikram,
Can you post the code you are using?  I could not reproduce this with the following sample:
http://developers.arcgis.com/javascript/samples/widget_measureproject/
VikramS
Hi Vikram,
Hello Jake,
I didn't realize that I had to set the Geometry Service .
esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
After I set ,I am not getting error . Thanks Jake for pointing out the sample .
