Opening tutorial for webapp
5405
14
09-08-2016 06:32 AM
MathewSuran
What is it called when there is a tutorial when you first open a webapp or webpage.  Basically instructions highlighting what to do in a few steps?  Are there other programs to build that in or is this done through javascript? Any resources anyone can direct me to?
Drew
Matt,
If you can post some sample code of a working app with the error I can see if I can figure out what is happening and maybe provide a working sample back to you.
Drew
MathewSuran
Ok, before I provide some code though, is there a way to provide a step, then have the user do that action which moves on to the next step?
Drew
Not that I know of. It basically highlights the node and you provide a some text . Then the user can click next.... Etc..
MathewSuran
That would be the ideal situation.  I am using Joyride at the moment since I can get the most functionality out of it but it doesnt have what I mentioned above.  Have you seen anything that has those capabilities?
Drew
I have not seen anything like that.
