Open Popup after adding client-side feature
2798
02-21-2024 06:38 AM
DavinShokes1
In my app:
  • The user searches for an address
  • A graphic is created for the search result
  • External API request data is added to graphic attributes
  • The graphic is added to a client side feature layer
  • The popup can be opened by clicking the new feature. However,
  • I'm trying to programmatically update/replace the existing popup with the popup for the new feature (Around line 283-316).
I can't figure out the correct code to show the popup. I've tried the advice from https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#queryFea... and https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#querying but I don't think I'm making the correct function.
Any advice? Thank you.
LaurenBoyd
Hi @DavinShokes1 -
You could try passing in the graphic that is added to the feature layer to the features property in the MapView's openPopup() method after the query/external API call completes. Here's a simple example showing how to use that property: https://codepen.io/laurenb14/pen/ZEPNpXG?editors=1000
You'll have to make sure the MapView popupEnabled property is set to false to manually open the popup as well.
Hope this helps!
Lauren
LaurenBoyd
Hi @DavinShokes1 -
Hope this helps!
Lauren
DavinShokes1
Thanks, that got me on the right path and my misunderstanding of the popupTemplate.
