onLayerAdd vs onLayerAddResult events
1171
04-05-2012 02:24 PM
JohnCartwright
Hello All,
Can someone please clarify for me the differences between the onLayerAdd and onLayerAddResult events on the esri.Map class?
Why would one choose not to use the new onLayerAddResult instead of the onLayerAdd?
Thanks!
--john
derekswingley1
Hi John,
onLayerAdd fires as soon as a layer is added to a map. onLayerAddResult fires after a add operation succeeded or failed. If you want to be notified when a layer is added, you probably want onLayerAddResult as you'll be able to check for success or failure.
