on Change select drop down 1st value by default
4938
6
11-03-2015 09:05 AM
AlexGole
Hi all, I am trying to get a UI that allows users to select Measurement values from a drop down menu. I have some code that works great but I have to first manually select  from drop down otherwise I get an "undefined" value.   I would like that if nothing is selected in drop down by user then it automatically uses the first value in drop down. Any idea why?
1) This how I change selected values in my drop down:
var areasUnits;
                var areasUnitsText;
                var LenghtUnits;
                var LenghtUnitsText;
                $('#Area').on('change', function () {
                    areasUnits = $(this).val();
                    areasUnitsText = $(this).find("option:selected").text();
                    alert(this.value)
                $('#Length').on('change', function () {
                    LenghtUnits = $(this).val();
                    LenghtUnitsText = $(this).find("option:selected").text();
2) This is my drop downs:
 <select id="Area" class="form-control">
                        <option value="UNIT_ACRES">Acres</option>
                        <option value="UNIT_SQUARE_MILES">Square Miles</option>
                        <option value="UNIT_ARES">Ares</option>
                        <option value="UNIT_HECTARES">hectares</option>
                        <option value="UNIT_SQUARE_FEET">Square Feet</option>
                        <option value="UNIT_SQUARE_KILOMETERS">Square Kilometers</option>
                        <option value="UNIT_SQUARE_METERS">Square Meters</option>
                    </select>
                    <div style=" width: 100%; border: solid; padding: 10px;"><span style="font-weight:bolder;">Results:</span> <span style="font-weight:bolder;" id="area"></span></div>
                    <br />
                    <p style=" font-style: italic; font-weight: bold; color:red;">Polylines</p>
                    <select id="Length" class="form-control">
                        <option value="UNIT_FOOT">Feet</option>
                        <option value="UNIT_KILOMETER">Kilometer</option>
                        <option value="UNIT_METER">Meter</option>
                        <option value="UNIT_STATUTE_MILE">Mile</option>
                    </select>
Tags (3)
thejuskambi
In the html tag set the selected value for the default option you want to be selected like below
<option value="UNIT_FOOT" selected>Feet</option>
AlexGole
thejuskambi
Can you set a jsbin or something which we can take a look at?
AlexGole
sure. I ll get back ill post it soon.
AlexGole
My code is here​. An attempt to reproduce what I am trying to do is here​ ( I have only set the area but not length). Thanks,
Alex
thejuskambi
Are you talking about the areaUnits and LenghtUnits variables? if so, they are not initialized until the change event on the dropdown occurs. otherwise I can see the dropdown has default selected value.
You can set a default value while initializing like
var areasUnits = dom.byId("Area").value;
