not extracting values correctly from URL
4013
18
08-30-2012 08:47 AM
deleted-user-ugCMpXci8bn5
I am trying to create a URL from the current extent (and including other parameters), and then be able to extract that extent from the URL and zoom to that extent on opening the app, with a default extent if there are no parameters in the URL.
What I am getting instead is an empty map when I load a URL with parameters.  I am not getting any errors in Firebug.  Below is the relevant code:
(to extract parameters:)
    var urlToObject = locale.substring(locale.indexOf("?") + 1, locale.length);
    var testURLExtent;
    urlToObject = dojo.queryToObject(urlToObject);
  if ( urlToObject.urlxmin != null)
   alert ("passed in extent from url");
   var locXmin = urlToObject.urlxmin;
   var locYmin = urlToObject.urlymin;
   var locXmax = urlToObject.urlxmax;
   var locYMax = urlToObject.urlymax;
  else
   alert ("no params, preset extent");
   var locXmin = 896338.273119375;
   var locYmin = 116730.668986593;
   var locXmax = 1089315.70367493;
   var locYMax = 274621.293986593;
  var testURLExtent = new esri.geometry.Extent (locXmin, locYmin, locXmax, locYMax,  new esri.SpatialReference({ wkid: 2263}));
(and to create URL, from a new extent:)
    var curExtent = {
   urlxmin: pointExtent.xmin,
   urlymin: pointExtent.ymin,
   urlxmax: pointExtent.xmax,
   urlymax: pointExtent.ymax,
          var url = "http://127.0.0.1:8020/MyApp/index.html";
    var queryStr = dojo.objectToQuery(curExtent);
    url= url + "?" + queryStr;
    alert (" url: " + url);
I notice that if I use only one parameter (such as xmin), and set the rest to constant values. the value is passed correctly from the URL, making me think there is a problem with the parsing of the parameters at the '&' sign?
Any help would be appreciated, thanks //
KellyHutchins
Esri Notable Contributor
If you navigate to just this portion of the url does the page load successfully?
http://127.0.0.1:8020/SchoolSafety/index.html
If you add a breakpoint to your app what is the line of code where your app fails?
yes it does.
well, I am trying to open the app with the created URL..so the page never loads at all, it immediately opens with the 'internal service error' message on a white screen.
(btw, this is the URL that is created using 'urlextent = "/?urlextent=" + dojo.toJson(pointExtent.toJson());' )
http://127.0.0.1:8020/SchoolSafety/index.html/?urlextent=%7B%22xmin%22:981583.5277170027,%22ymin%22:...
KellyHutchins
This part of the url is incorrect
There shouldn't be a / in front of the ?.
Here's an example that works for me:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Topographic Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      var map;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":-122.46,"ymin":37.73,"xmax":-122.36,"ymax":37.77,"spatialReference":{"wkid":4326}});
        map = new esri.Map("map",{
          extent:esri.geometry.geographicToWebMercator(initExtent)
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
         //if there are url params zoom to location
         var coords, zoomLevel;
         var urlObject = esri.urlToObject(document.location.href);
        if(urlObject.query && urlObject.query.urlExtent){
          map.setExtent(new esri.geometry.Extent(dojo.fromJson(urlObject.query.urlExtent)));
        dojo.connect(map, 'onLoad', function(theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
       function generateUrl(){
          //construct url param at current extent
          var extent = dojo.toJson(map.extent.toJson());
          var url = location.protocol + '//' + location.host + location.pathname + '?urlExtent=' + encodeURIComponent(extent);
          console.log(url);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;">
      <div dojotype='dijit.layout.BorderContainer' region='top' style='height:20px;'>
      <input type='button' onClick='generateUrl();' value='Generate URL (see console)'/>
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;">
     </div>
    </div>
  </body>
</html>
My earlier version did not have the slash; I tried that to see if it would help...
With or without the slash, I get the same error message.
I'll keep trying, thanks.
KellyHutchins
Jason,
Can you try this code and see if it works for you?
<html>
  <head>
      on iOS devices-->
    <style>
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
    </style>
      var map;
      function init() {
          console.log(url);
    </script>
  </head>
      </div>
     </div>
    </div>
  </body>
</html>
When i click the button in your code I get this URL:
http://127.0.0.1:8020/SchoolSafety/testURLcreator.html?urlExtent=%7B%22xmin%22%3A-13632724.275638657...
..but when I cut and paste this URL and try to navigate to it, I get that same "Internal Server Error" message on a blank screen.
In Firebug I get "NetworkError: 500 Internal Server Error" followed by the URL.
Hello, just checking in again, I didn't see a response..to recap, I was able to run this example, but I received the same error ("Internal Server Error") when I tried to navigate to the generated URL.
Any thoughts on why this is so? Thanks, jason
KellyHutchins
500 errors come from teh server - for some reason the server wasn't able to fulfill the request. Here's some info on troubleshooting 500 errors:
http://pcsupport.about.com/od/findbyerrormessage/a/500servererror.htm
I am now testing the app from our development server...when I try to navigate to a URL with the extent variables, I now get these errors:
exception in animation handler for: onEnd
TypeError: lod is undefined
Do these errors help give an explanation as to why this isn't working for me?
Thanks, Jason
