Not able to add Sketch widget
1590
10-23-2024 09:02 AM
olega
I'm trying to add Sketch widget to my map as well as add some polygons based on info previously submitted.
When adding the widget an error is shown in the console and widget is not visible. Used a lot of time to figure it out without any luck. Hopefully someone can help me.
Here is the error message:
And here is my complete code:
require([
    "esri/widgets/Sketch",
    "esri/Map",
    "esri/views/MapView",
    "esri/Graphic",
    "esri/layers/GraphicsLayer"
], (Sketch, Map, MapView, Graphic, GraphicsLayer) => {
    let graphicsLayer = new GraphicsLayer();
    var jsonString = "${sys_json_object}"; // server-side directive to import json
    var jsonObj = JSON.parse(jsonString);
    var map = new Map({
        basemap: "streets-navigation-vector",
        layers: [graphicsLayer]
    var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: jsonObj.zoom,
        center: [jsonObj.center.longitude, jsonObj.center.latitude]
    view.when(() => {
        let sketch = new Sketch({
            layer: graphicsLayer,
            view: view
        view.ui.add(sketch, 'top-right');
        var polygon = {
            type: "polygon",
            rings: jsonObj.rings,
            spatialReference: jsonObj.spatialReference
        var fillSymbol = {
            type: "simple-fill",
            color: [227, 139, 79, 0.8], // Orange, semi-transparent
            outline: {
                color: [255, 255, 255],
                width: 1
        var polygonGraphic = new Graphic({
            geometry: polygon,
            symbol: fillSymbol
        graphicsLayer.graphics.add(polygonGraphic);
If I comment out line 34, the polygon is drawn correctly, but obviously no widget shown.
LittleTurtle
Hello, maybe try adding your polygonGraphic before creating your Sketch
RamaniGanason
Can post your source where the viewDiv is created. The problem dont seems like to be with your Sketch.
