Newline or carriage return in TextSymbol
6254
7
09-01-2011 06:28 AM
AndrewJones
Is there anyway to make a TextSymbol multi-lined?  Our map is quite small and many of the labels go off the map so I need to reduce the width of the label by putting some values onto two lines.
The product manager does not want to use a popup as it must look like a label.
Any clues?
JeffPace
Any clues?
I don't have a sample in front of me to test, but have your tried \\n in the text?
JesseAdams
Did anyone ever find a solution to this?  I'm trying to do the same thing but \n or \r don't work.  Any other suggestions?
GISAdmin1
Bump - I too have the same question.  Is it possible to have multiline text rendered via TextSymbol?
Thanks!
M
derekswingley1
Not at this time, this is a limitation in the API (and underlying dojox.gfx components we use). We're looking at how we can fix this in the future.
SimonUyttendaele
Hello,
Using newlines "\n" can be supported using the following solution.
Please vote upon the following idea which is precisely about this.
Regards
JohnChurchill
What solution? There is nothing here in these links.
by Anonymous User
Not applicable
I just found this on github: Chaussette/esri.symbol.MultiLineTextSymbol · GitHub from a comment by Simon in ArcGIS Ideas.
However when you include the script src use (or host it yourself):
"https://rawgit.com/Chaussette/esri.symbol.MultiLineTextSymbol/master/esri.symbol.MultiLineTextSymbol...
