New Error exposed in 3.18 for Basemap Gallery
6722
13
09-23-2016 04:08 PM
DEWright_CA
With the update to reference 3.18 we are now finding that we get this message returned:
esri.dijit.BasemapGallery: Unable to switch basemap because new basemap has a different spatial reference.
Yet if we select our Basemap toggle we can switch without issue; the problem only happens on the initial load of the page.
DEWright_CA
In our instance we are using custom basemaps that reflect our states boundaries and needs. When I add that property; I get this error returned to me:
Map.setBasemap: Unable to find basemap definition for: "streetBasemap". Try one of these: streets,satellite,hybrid,terrain,topo,gray,dark-gray,oceans,national-geographic,osm,dark-gray-vector,gray-vector,streets-vector,topo-vector,streets-night-vector,streets-relief-vector,streets-navigation-vector.
Is this dependent on the Title ("Streets") of the map; or the name of the basemap-object I created when instantiating my gallery as defined in JavaScript?
RobertScheitlin__GISP
David,
   You must use one of the contant names as indicated by the message: basemap: "streets"
JeffJacobson
You'll need to add your custom basemap to the esri/basemaps list before creating the esri/Map object.
prashantnigam
Is this issue resolved?? I am still unable to set the Image service as basemap. I am not using esri-basemaps and using custom basemaps through basemap gallery.
