Network analyst in a building
1265
09-01-2011 01:14 AM
miguelde_la_roda
My problem is I want to trace routes between various points and floors of a building and display it in 2D maps. In the first map of the route would go from the starting point for elevator / stairs on the second map from the elevator / stairs to the destination. Is there any way of linking points to trace routes Network Analyst automatically and display 2 different maps?
Now, I'm doing manually calculate the midpoint (elevator / stairs) and shows two routes, one for each map. I want to add barriers and the issue becomes more complicated with alternate routes to other plants and hallways of the building.
What do you think?
Thank you very much and sorry my bad English, I hope you understand.
miguelde_la_roda
Does anyone have any idea?
StephenLead
Honored Contributor
Hi Miguel,
You might need to post this question on the Network Analyst forum.
This forum is for people using the ArcGIS Server JavaScript API, and most of us probably don't know much about Network Analyst.
Steve
miguelde_la_roda
Thanks Steve.
I'll try it.
