Need to add a layer to a sample script, But HOW...???
760
11-30-2011 04:32 PM
MatthewLopez
I am trying to add these bike routes from (https://gis.sanantonio.gov/ArcGIS/rest/services/BikeFacilities/MapServer)
to this sample script ESRI provides on there website.
I can't find where to put the bike routes url and not sure what function to use.
I am trying to generate the bike routes within the basemap. (script below)
Any help would be greatly appreciated:-)
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
  <html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{
        padding:0;
    </style>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
      dojo.require("dijit.dijit"); // optimize: load dijit layer
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.virtualearth.VETiledLayer");
      dojo.require("dijit.TitlePane");
      dojo.require("esri.dijit.BasemapGallery");
      dojo.require("esri.arcgis.utils");
      var map = null;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":-2116239,"ymin":13663172,"xmax":-2145203,"ymax":13713995,"spatialReference":{"wkid":2278}});
        map = new esri.Map("map",{extent:initExtent});
        var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(initBasemap);
        createBasemapGallery();
        //resize the map when the browser resizes
        dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      function createBasemapGallery() {
        //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
        var basemapGallery = new esri.dijit.BasemapGallery({
          showArcGISBasemaps: true,
          bingMapsKey: 'Enter your Bing Maps Key',
          map: map
        }, "basemapGallery");
        basemapGallery.startup();
        dojo.connect(basemapGallery, "onError", function(msg) {console.log(msg)});
      //show map on load
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%;height:100%;margin:0;">
    <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div dojoType="dijit.TitlePane" title="Switch Basemap" closable="false"  open="false">
          <div dojoType="dijit.layout.ContentPane" style="width:380px; height:280px; overflow:auto;">
          <div id="basemapGallery" ></div></div>
        </div>
      </div>
      </div>
    </div>
  </body>
  </html>
KellyHutchins
Esri Notable Contributor
Matt,
Here's a revised version of the code. The bike routes were added to the map as a DynamicMapServiceLayer. I also modified the extent so that the map opened zoomed into San Antonio. Since the basemap (World_Topo) is in Web Mercator (102100) I specified the San Antonio extent using coordinates that are valid for Web Mercator.
<html>
<head>
on iOS devices-->
<title>
</title>
#map{
padding:0;
</style>
var djConfig = {
parseOnLoad: true
</script>
var map = null;
function init() {
var initExtent = new esri.geometry.Extent({"xmin":-11123269.230112463,"ymin":3379128.146430188,"xmax":-10804373.948106863,"ymax":3478190.535087729,"spatialReference":{"wkid":102100}});
var bikeRoutes = new esri.layers.ArcGISDynamicMapServiceLayer("https://gis.sanantonio.gov/ArcGIS/rest/services/BikeFacilities/MapServer");
map.addLayer(bikeRoutes);
map: map
//show map on load
</script>
</head>
</div>
</div>
</div>
</div>
</body>
</html>
