Need help with routing codes!
1039
03-27-2012 11:11 PM
JacobLim
These are the codes that me and my partner have done so far.. However we can't seem to solve the routes from Point A to Point B
<head id="Head1" runat="server">
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>Happy Family Portal</title>
    <script type="text/javascript" src="http://www.onemap.sg/API/JS?accessKEY=xkg8VRu6Ol+gMH+SUamkRIEB7fKzhwMvfMo/2U8UJcFhdvR4yN1GutmUIA3A6r..."></script>
    <script type="text/javascript">
        dojo.require("esri.map");
        dojo.require("esri.tasks.query");
        dojo.require("esri.tasks.geometry");
        dojo.require("esri.toolbars.draw");
        dojo.require("esri.tasks.route");
//routing
        var divMain, routeTask, routeParams;
        var stopSymbol, routeSymbol, lastStop, barrierSymbol;
        var segmentSymbol, segmentGraphic;
        var OneMap = new GetOneMap('divMain', 'SM');
        var totalDistance = 0;
        var totalTime = 0;
        var f;
        var mapOnClick_addBarriers_connect, mapOnClick_addStops_connect;
        var dojoConnections = [];
        var barriersArray = [];
        function initStop() {
            mapOnClick_addStops_connect = dojo.connect(map, "onClick", addStop);
            routeParams.stops = new esri.tasks.FeatureSet();
            stopSymbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE).setSize(15);
            stopSymbol.outline.setWidth(4);
        function solveRoute(routeParams) {
            routeTask.solve(routeParams);
        function clearRoutes() {
            for (var i = routes.length-1; i>=0; i--) {
                map.graphics.remove(routes.splice(i, 1)[0]);
            routes = [];
        //Clear barriers
        function clearBarriers() {
            removeEventHandlers();
            for (var i = routeParams.barriers.features.length - 1; i >= 0; i--) {
                map.graphics.remove(routeParams.barriers.features.splice(i, 1)[0]);
        function initBarrier() {
            mapOnClick_addBarriers_connect = dojo.connect(map, "onClick", addBarrier);
            routeParams.barriers = new esri.tasks.FeatureSet();
            barrierSymbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CROSS).setSize(10);
            barrierSymbol.outline.setWidth(3).setColor(new dojo.Color([255, 0, 0]));
        function addBarrier(evt) {
            var barrier = map.graphics.add(new esri.Graphic(evt.mapPoint, barrierSymbol));
            routeParams.barriers.features.push(barrier);
            //barriersArray.push(barrier);
            //routeTask.solve(routeParams);
        function removeEventHandlers() {
            dojo.disconnect(mapOnClick_addBarriers_connect);
            dojo.disconnect(mapOnClick_addStops_connect);
        //Adds the solved route to the map as a graphic
        function showRouteV(routeResults, barriers, messages) {
            clearRoutes();
            var distance;
            var time;
            var directions = routeResults[0].directions;
            var directionFeatures = directions.features;
            map.graphics.add(routeResults[0].route.setSymbol(routeSymbol));
            distance = formatDistance(directions.totalLength);
            totalDistance += distance;
            time = minsCal(directions.totalTime);
            totalTime += time;
             dojo.byId("divResults").innerHTML = "  Total distance: " + totalDistance + "<br />   Total time: " + totalTime;
            dojo.forEach(routeResults[0].directions.features, function (feature, i) {
                dirStrings.push("<li onclick='zoomToSegment(" + i + "); return false;' class=\"segment\"><a href=\"#\">" + feature.attributes.text + " (" + formatDistance(feature.attributes.length, "km") + ", " + formatTime(feature.attributes.time) + ")</a></li>");
            dojo.forEach(routeResults, function (routeResult, i) {
                routes.push(map.graphics.add(routeResult.route.setSymbol(routeSymbols[routeResult.routeName])));
            dojo.byId("divResults").innerHTML = dirStrings.join("");
            dojo.byId("divResult").innerHTML = "  Total distance: " + roundDistance(totalDistance, 2) + " Kilometres <br />   Total estimated time: " + roundTime(totalTime, 2) + " min(s)";
        //Displays any error returned by the Route Task
        function errorHandler(err) {
            alert("An error occured\n" + err.message + "\n" + err.details.join("\n"));
            routeParams.stops.features.splice(0, 0, lastStop);
            map.graphics.remove(routeParams.stops.features.splice(1, 1)[0]);
        function zoomToSegment(index) {
            var segment = directionFeatures.route[index];
            map.setExtent(segment.geometry.getExtent(), true);
            if (!segmentGraphic) {
                segmentGraphic = map.graphics.add(new esri.Graphic(segment.geometry, segmentSymbol));
            else {
                segmentGraphic.setGeometry(segment.geometry);
        //Format the time as hours and minutes
        function formatTime(time) {
            var hr = Math.floor(time / 60), //Important to use math.floor with hours
            min = Math.round(time % 60);
            if (hr < 1 && min < 1) {
                return "";
            else if (hr < 1) {
                return min + " minute(s)";
            return hr + " hour(s) " + min + " minute(s)";
        //Round the distance to the nearest hundredth of a unit
        function formatDistance(dist) {
            var d = Math.round(dist * 100) / 100;
            if (d === 0) {
                return ""
            return d;
        //Round the distance to 2 decimal places
        function roundDistance(dist, dec) {
            var result = Math.round(dist * Math.pow(10, dec)) / Math.pow(10, dec);
            return result;
        //to store the time in mins
        function minsCal(time) {
            var min = time;
            return time;
        //round the time to 2 decimal place
        function roundTime(time, dec) {
            var result = Math.round(time * Math.pow(10, dec)) / Math.pow(10, dec);
            return result;
        //endroute
        function GetRouting(routeParams) {
            alert("Please wait.........Route is being calculated.");
        function showRoute(routeResults, barriers, messages) {
            clearRoutes();
            //Add route to the map
                routes.push(map.graphics.add(new esri.Graphic(directions.mergedGeometry, routeSymbol)))
<body class="tundra">
    <form id="form1" runat="server">
    <table style="width: 1309px">
        <tr>
            <th colspan="3" class="style7" align="left">
       <div id="Header1" style="float: left">
       <asp:Image ID="Image1" runat="server" Height="101px"
                    ImageUrl="~/images/HF_logo2.gif" Width="321px" />
       </div>
            </th>
        </tr>
        <tr>
            <td style="vertical-align: top" class="style4" >
                <div id="SearchCategory">
                    <asp:Image ID="Image3" runat="server" Height="40px"
                        ImageUrl="~/images/Headers/dynamicrouting_header.gif" Width="170px" />
                    <a id="displayText" href="javascript:toggle();" style="vertical-align: middle">[+]</a>
                    <div id="toggleText" style="display: none">
                    <input type="button" onclick="initStop();" value="Add Stops"
                    style="width: 207px"/>
                    <input type="button" onclick="removeEventHandlers();" value="Stop"
                    <input type="button" onclick="initBarrier();" value="Add Barrier"
                    <input type="button" onclick="solveRoute();" value="Solve Route"
                    <input type="button" onclick="clearBarriers();" value="Clear barriers"
                    </div>
                    <br />
                </div>
</form>
</body>
</html>
