need help migrating to AMD
2784
6
08-21-2013 09:50 AM
JeffPace
So i have a utilities folder with a common.js that contains a bunch of helper methods.  Pre AMD it looked like.  NO idea how to migrate to AMD.  THANKS!
dojo.provide("utilities.common");
utilities.common.getType = function(value) {
    var type = "config.json";
    switch (value) {
        case "test":
            type = "config-test.json";
            break
        case "landdevelopment":
            type = "config-landdevelopment.json";
            break
        case "utilitiesinfrastructure":
            type = "config-utilitiesinfrastructure.json";
            break
        default:
    return type;
utilities.common.getFormattedServiceType = function(value) {
    var type = "Property Locator";
    var newValue = (value.replace(".json", "")).replace('config-', '');
    switch (newValue) {
        case "test":
            type = "Test";
            break
            type = "Land Development";
            break
            type = "Utilities Infrastructure";
            break
        default:
    return type;
utilities.common.getAllNamedChildDijits = function(id) {
    // Gather all child widgets
    var w = null;
    var children = null;
    widgets = {};
    w = dojo.query("[widgetId]", dojo.byId(id));
    children = w.map(dijit.byNode);
    children.forEach(function(item, idx) {
        if (item.name) {
            widgets[item.name] = item;
    return widgets;
derekswingley1
You can pass an object to define() that defines your utility functions. Put this in common.js:
define({
    getType: function(value) {
        switch (value) {
            case "test":
                break
                break
                break
            default:
        return type;
    getFormattedServiceType: function(value) {
        switch (newValue) {
            case "test":
                type = "Test";
                break
                break
                break
            default:
        return type;
    getAllNamedChildDijits: function(id) {
        var w = null;
        widgets = {};
            if (item.name) {
        return widgets;
Put this in load-common.html in the same directory as common.js:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title></title>
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
    </style>
    <script>
      var dojoConfig = {
        paths: {
          utilities: location.pathname.replace(/\/[^/]+$/, "")
    </script>
    <script src="//js.arcgis.com/3.6/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "utilities/common",
        "dojo/domReady!"
      ], function(
        Map, common
        map = new Map("map", {
          basemap: "streets",
          center: [ 19.291, 48.343 ],
          zoom: 4
        console.log("common", common);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
JeffPace
define({
        switch (value) {
            case "test":
                break
                break
                break
            default:
        return type;
        switch (newValue) {
            case "test":
                type = "Test";
                break
                break
                break
            default:
        return type;
        var w = null;
        widgets = {};
            if (item.name) {
        return widgets;
<!DOCTYPE html>
<html>
  <head>
    <title></title>
    <style>
      html, body, #map {
    </style>
    <script>
      var dojoConfig = {
        paths: {
    </script>
    <script>
      var map;
      require([
        "esri/map",
        "utilities/common",
        "dojo/domReady!"
      ], function(
        Map, common
          basemap: "streets",
          zoom: 4
    </script>
  </head>
  <body>
  </body>
</html>
appreciate that.  I can load it from my index.html as long as i path to it correctly right?
also, what about defining the components properly so in the third function i can use "query" instead of "dojo.query"?
JasonZou
You put dependencies in the first parameter as an array, and use aliases as the callback function parameters once all the dependencies are loaded. Inside the callback function, you can use the aliases instead.
define(["dojo/dom", "dojo/query"], function(dom, query) {
        switch (value) {
            case "test":
                break
                break
                break
            default:
        return type;
        switch (newValue) {
            case "test":
                type = "Test";
                break
                break
                break
            default:
        return type;
        var w = null;
        widgets = {};
        w = query("[widgetId]", dom.byId(id));
            if (item.name) {
        return widgets;
derekswingley1
Yep.
My mistake, missed those refs initially.
Do what zj_zou says:  load your dependencies using an array of module identifiers for the first arg to define(). Also make sure you return the object you create like so:
    return {
            switch (value) {
                case "test":
                    break
                    break
                    break
                default:
            return type;
            switch (newValue) {
                case "test":
                    type = "Test";
                    break
                    break
                    break
                default:
            return type;
            var w = null;
            widgets = {};
                if (item.name) {
            return widgets;
Here's a test page that loads and calls two of your functions (I renamed common.js from my previous example to common-deps.js):
<!DOCTYPE html>
<html>
  <head>
    <title></title>
    <style>
      html, body, #map {
    </style>
    <script>
      var dojoConfig = {
        paths: {
    </script>
    <script>
      var map;
      require([
        "esri/map",
        // "utilities/common",
        "utilities/common-deps",
        "dojo/domReady!"
      ], function(
        Map, common
          basemap: "streets",
          zoom: 4
        console.log("all of common", common);
        console.log("common.getType(\"test\"):", common.getType("test"));
        console.log("common.getAllNamedChildDijits(\"map\"):", common.getAllNamedChildDijits("map"));
    </script>
  </head>
  <body>
  </body>
</html>
JeffPace
perfect thank you.  Lots of classes to re-write.  🙂
JasonZou
Jeff, please mark this as answered so other developers may find it helpful for their conversion job. Thanks.
