Navigation | AMD Module Require, Event onExtentHistoryChange()!
1380
06-17-2013 06:21 AM
YgorThomaz
Hello guys,
What's wrong with my javascript AMDDojo code? I can't associate the event onExtentHistoryChange in my object navToolbar.
The functions of the Navigation works.
Code below:
var map, navToolbar;
require(["dojo/_base/connect", "esri/map", "esri/toolbars/navigation", "dijit/registry", "dijit/form/Button", "dojo/domReady!"],
    function (
        connect,
        Map,
        Navigation,
        registry,
        Button
        map = new Map("mapDiv", {
            center: [-56.049, 38.485],
            zoom: 3,
            basemap: "gray"
      // ERROR : object is not a function
        navToolbar = new Navigation(map);
        connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
        function extentHistoryChangeHandler() {
            registry.byId("zoomprev").disabled = navToolbar.isFirstExtent();
            registry.byId("zoomnext").disabled = navToolbar.isLastExtent();
        var buttonZoomin = new Button({
            iconClass: 'zoominIcon',
            onClick: function () {
                navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);
        }, "zoomin");
        var buttonZooout = new Button({
            iconClass: 'zoomoutIcon',
                navToolbar.activate(esri.toolbars.Navigation.ZOOM_OUT);
        }, "zoomout");
        var buttonPan = new Button({
            iconClass: 'panIcon',
                navToolbar.activate(esri.toolbars.Navigation.PAN);
        }, "pan");
        var buttonZoomfullext = new Button({
            iconClass: 'zoomfullextIcon',
                navToolbar.zoomToFullExtent();
        }, "zoomfullext");
        var buttonZoomprev = new Button({
            iconClass: 'zoomprevIcon',
                navToolbar.zoomToPrevExtent();
        }, "zoomprev");
        var buttonZoomnext = new Button({
            iconClass: 'zoomnextIcon',
                navToolbar.zoomToNextExtent();
        }, "zoomnext");
        var buttonDeactivate = new Button({
            iconClass: 'deactivateIcon',
                navToolbar.deactivate();
        }, "deactivate");
    <div id="toolbar" data-dojo-type="dijit/Toolbar">
        <button id="zoomin" type="button"></button>
        <button id="zoomout" type="button"></button>
        <button id="pan" type="button"></button>
        <button id="zoomfullext" type="button"></button>
        <button id="zoomprev" type="button"></button>
        <button id="zoomnext" type="button"></button>
        <button id="deactivate" type="button"></button>
    </div>
    <div id="mapDiv">
    </div>
I tried using dojo / on and nothing!
References: https://developers.arcgis.com/en/javascript/jsapi/navigation-amd.html#onextenthistorychange and http://dojotoolkit.org/reference-guide/1.9/dijit/form/Button.html
Thank you!
KenBuja
MVP Esteemed Contributor
I believe you have to use dojo.connect or connect.connect instead. See this thread
YgorThomaz
Excellent, that works.
KenBuja
Glad to help.
Please remember to click the check and the up arrow on the post to signify your question was answered.
