Nav Toolbar Compatibility Problems in IE10
3271
8
10-16-2013 04:51 PM
JohnHaasbeek
Try the nav toolbar sample from the API samples page in IE10.  The zoom in and zoom out work but do not display a marquee rectangle as you click and drag.
Found this problem in my own code using the nav toolbar and tried the meta tag:
<meta http-equiv="X-UA-Compatible"  content="IE=9" />
This became even wierder - the rectangle would display correctly the first time i zoomed but after that the zoom cursor would stay at the original click location as the rectangle expanded while I dragged, and the map in the background was panning as I dragged.  The zoom would then work but it was ugly.  Same behavior with content="IE=8".
Not sure what other incompatibilities I will find but this is very disconcerting.  Anyone out there got a workaround or an alternative solution?
Cheers,
JH
AdrianMarsden
Honored Contributor
I had a similar issue - see http://forums.arcgis.com/threads/87962-IE10-and-zoom-box-fail?highlight=ie10+zoom
But it has returned, and my previous "fix" seems to not work.
AdrianMarsden
Honored Contributor
PS - <meta http-equiv="X-UA-Compatible" content="IE=9"/> works for me.  Also, without it the draw tools are borked.
Also see http://forums.arcgis.com/threads/88426-Shift-Draw-Rectangle-on-the-map-to-zoom-in-does-not-work-in-I... which confirms this behaviour.
Esri - is this a listed bug?
SubaKrishnan
Hello,
Our development team is currently working on the issue. Most likely, it will be fixed in the upcoming release.
Thanks!
AdrianMarsden
Honored Contributor
Many thanks - is it an official bug or something else?
JohnHaasbeek
Same behavior in Chrome 30.0.1599.101 - any update on the timing for this fix?  At this point I am forced to remove the fixed zoom functions from my applications.
John H.
AdrianMarsden
Honored Contributor
Bearing in mind that in IE10+ Conditional Comments are no longer supported any ideas how I would detect if IE8 or IE10 and use a different metatag - basically, this is what I would use is conditional comments were supported
<!--[if lte IE 8]><meta http-equiv='X-UA-Compatible' content='IE=edge,chrome=1'><![endif]-->
<!--[if IE 10]><meta http-equiv="X-UA-Compatible" content="IE=9" /> <![endif]-->
As our IE8 users use Google Chrome frame to improve performance, whereas our IE10 users need to run it as IE9.
ACM
KenBuja
MVP Esteemed Contributor
John H.
This isn't happening on Chrome 31.0.1650.57. The marquee rectangle does appear on Zoom In and Zoom Out
AdrianMarsden
Honored Contributor
Hello,
Thanks!
Still an issue with 3.8.
