MS JScript runtime error: dojo is undefined
1394
03-20-2012 03:25 AM
CliveSwan
I am getting a MS JScript runtime error: dojo is undefined in Line 1
I have the dojo listed in TEST.js
dojo.require("dijit.dijit"); // Line 1
dojo.require("dijit.form.Button");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.layout.TabContainer");
dojo.require("dijit.layout.AccordionContainer");
dojo.require("dijit.form.CheckBox");
dojo.require("dijit.ProgressBar");
dojo.require("dijit.Tooltip");
dojo.require("dijit.Toolbar");
dojo.require("dojo.NodeList-traverse");
ChadWilcomb
Hi Clive, you need to include a reference to the API and the var dojoConfig = {parseOnLoad: true}; before you call the dojo.requires
<script>
      var dojoConfig = {
        //Required if you have dojo widgets(aka.dijits) in your HTML markup
        parseOnLoad: true
</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.7">
<script type="text/javascript">
</script>
