mouse cursor stuck with the map
899
07-04-2010 11:34 PM
saurabhjain
Hi ,
I am facing a problem with the ArcGIS API for JavaScript: my problem is basically in IE-6.0 if i continuously PAN the map fast then the mouse cursor is getting stuck with the map and then after if i move the mouse cursor in any direction then map is also getting moved in the same direction.
This same problem i experienced with the ESRI samples also provided in the ESRI JavaScript API help site.
Please help me to find out solution of the problem as i am not able to figure out whether this is a bug in the JavaScript API or somewhere i am doing wrong.
Thanks in advance , waiting for reply.
Saurabh Jain
NIIT Tecchnoligies Pte. Ltd. Singapore
DonKang
I know this is a old post.
But did you ever figure out this issue?
I am having similar issue and not sure where to begin?
thanks
Don Kang
