Modify Login Window - Secured Services
1144
06-02-2014 05:46 AM
jaykapalczynski
Honored Contributor
When you create a JS app and add Secured Services it automatically creates a popup window to Authenticate the user and the data that is trying to access.
Questions:
1. How can I modify this popup and change its appearance and location in the app (If possible).  Can I recreate its appearance?
2. Is there a widget that I can leverage that will completely replace this and allow the user to login to a main page and then create some sort of session variable that will time out but allow the user to refresh without having to add their credentials every time.
jaykapalczynski
Honored Contributor
I think this  (https://developers.arcgis.com/javascript/jssamples/widget_identitymanager_client_side.html) sort of addresses Number 2 above.  It allows to the credentials to be stored and a refresh does not kick off the login window again.
I guess my ONLY question now is how to modify the login window?  Is this possible?  Even if I was able to change the text, color, transparency etc.....
Thoughts?
JeffPace
I would love to override the dialog with a simple "Please log in" as opposed to the rest endpoint address
