Mobile Map browsing crashes application
844
10-02-2012 07:04 AM
LuisCÃ_spedes
I have created a mobile app using dojox mobile to make it look like an iphone app.
It does all that its supposed to do on the tables but when the map is activated certain mobile devices cant handle the map caches. After panning in say, a Blackberry curve, for a few minutes, the application crashes. The browser shows an error message.
Also, on other devices such as the iphone, androids, if the application is left open for a period of over 15 minutes and you come back to it, it does not respond. It may do the queries, but there will be no map. You have to hard refresh the whole application to make it work again.
My questions are, is there a way to flush the cache when a user initiates a search so the map tiles dont take up space (like destroy the map and recreated on demand)? and, is it ok of a practice to refresh the application every 15 minutes for the user?
Thanks all.
by Anonymous User
Not applicable
Hi cespedel 🙂 ,
I have not encountered a problem with the app being unresponsive after a certain amount of time has passed, say 15 minutes.  Can you post some of the code?  Could you elaborate on the map cache issue?  Are you referring to the map cache on the server, or the tiles that get stored on the client side?
