Mixed format tiled map service won't display in javascript api
885
02-27-2014 10:11 AM
KevinJohnson
Hi, I've got a tiled map service that displays fine in flex api, in silverlight, in arcmap,  but not javascript api since moving the cache from an arcgis server 10 machine to 10.1 (it did display fine in js api when being served from a 10.0 server).  My other cached map service which the tiles are format jpeg displays fine in javascript api from the new 10.1 server.  The  map service with the problem has tile image format of "Mixed"..   Does anyone know if this type of tiled service not supported in javascript api from a 10.1 server or is this a bug, or maybe has something to do with the migration of the cache to the new server...     just trying to rule some things out.
Thanks a lot.
here are some details from the service directory:
Single Fused Map Cache: true
Tile Info:
Height: 512
Width: 512
DPI: 96
Levels of Detail: 14
Level ID: 0 [ Start Tile, End Tile ]
Resolution: 0.10416666666666667
Scale: 120
Level ID: 1 [ Start Tile, End Tile ]
Resolution: 0.20833333333333334
Scale: 240
Level ID: 2 [ Start Tile, End Tile ]
Resolution: 0.4166666666666667
Scale: 480
Level ID: 3 [ Start Tile, End Tile ]
Resolution: 0.5208333333333334
Scale: 600
Level ID: 4 [ Start Tile, End Tile ]
Resolution: 1.0416666666666667
Scale: 1200
Level ID: 5 [ Start Tile, End Tile ]
Resolution: 1.4583333333333335
Scale: 1680
Level ID: 6 [ Start Tile, End Tile ]
Resolution: 2.0833333333333335
Scale: 2400
Level ID: 7 [ Start Tile, End Tile ]
Resolution: 4.166666666666667
Scale: 4800
Level ID: 8 [ Start Tile, End Tile ]
Resolution: 8.333333333333334
Scale: 9600
Level ID: 9 [ Start Tile, End Tile ]
Resolution: 15.625000000000002
Scale: 18000
Level ID: 10 [ Start Tile, End Tile ]
Resolution: 31.250000000000004
Scale: 36000
Level ID: 11 [ Start Tile, End Tile ]
Resolution: 41.66666666666667
Scale: 48000
Level ID: 12 [ Start Tile, End Tile ]
Resolution: 62.50000000000001
Scale: 72000
Level ID: 13 [ Start Tile, End Tile ]
Resolution: 108.50694444444446
Scale: 125000
Format: Mixed
Compression Quality: 75.0
Origin: X: -1.5822E7
Y: 3.3315599999999993E7
Spatial Reference: 102709  (3423)
Initial Extent:
XMin: 2230936.559916945
YMin: 1.484664112464784E7
XMax: 2323003.654913731
YMax: 1.4899482191160783E7
Full Extent:
XMin: 2131158.2962532546
YMin: 1.4702703773002457E7
XMax: 2379417.816155119
YMax: 1.497342893080594E7
