Missing base map tile in mobile/compact build?
2488
02-26-2014 05:07 AM
TracySchloss
Honored Contributor
I am working through a basic mobile example using dojo and the 3.8 compact build.  When I go to the mobile view that shows the map, it is cropped to a very narrow width.  I thought at first I had a style problem, but everything is set to width of 100% .  In my Firebug console, I'm getting an error on two of the base map tiles.  I have switched to a different base map, from topo to streets, and I'm getting the same type of error:
"NetworkError: 404 Not Found - http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer/tile/19/196231/124095?b..."
124095...e=false
"NetworkError: 404 Not Found - http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer/tile/18/98115/62047?bla..."
Has anyone encountered this before?  I am getting some of the tiles, just not all of them.  I remember there were some recent updates to the base maps. My other maps that use them draw fine, I'm just having problems with this one map.
AnjithaSenarath4
I have same issue. It is a buy in new JavaScript library (4.0) ?
