Message  "No Legend"
3261
6
12-14-2012 03:29 AM
JoseSanchez
Hi all
I just started downloading this sample  "Map container split left"  that has a tab with a Legend
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
and replaced the dynamicUrl map service with my service:
  var dynamicUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyHazardsandRisks/...";
        var referenceUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer";
        dynamicUrl = "http://<myserver>/ArcGIS/rest/services/OneLayer/MapServer";
When I run it I get instead of the Legend the following error message: "No Legend"
The map has a legend I just checked running it in my browser   http://<myserver>/ArcGIS/rest/services/OneLayer/MapServer/legend
This is the code I am running from the sample:
          dynamicUrl = "http://<myserver>/ArcGIS/rest/services/WASDDefault/MapServer";
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl);
        var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer(dynamicUrl,{opacity:0.45});
        var referenceLayer = new esri.layers.ArcGISTiledMapServiceLayer(referenceUrl);
        dojo.connect(map,'onLayersAddResult',function(results){
         //add the legend
          var legend = new esri.dijit.Legend({
            map:map,
            layerInfos:[{layer:dynamicLayer,title:""}],
            arrangement:esri.dijit.Legend.ALIGN_RIGHT
          },"legendDiv");
          legend.startup();
        map.addLayer(basemap);
        map.addLayers([dynamicLayer,referenceLayer]);
JakeSkinner
Esri Esteemed Contributor
Hi Jose,
I noticed you have the DynamicUrl specified twice.  Is your service drawing and the legend not displaying, or is your service not drawing as well as the legend?
JoseSanchez
I removed the line and it does the same thing.
It has to be related to the local map
   dojo.connect(map, 'onLoad', function (map) {
                //resize the map when the browser resizes
                dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
            var basemapUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer";
            //var dynamicUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyHazardsandRisks/MapServer";
       var dynamicUrl = "http://<localserver>/ArcGIS/rest/services/OneLayer/MapServer";
            var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer(dynamicUrl, { opacity: 0.45 });
            legendLayers.push({ layer: dynamicLayer, title: "Dolfin" });
            dojo.connect(map, 'onLayersAddResult', function (results) {
                //add the legend
                    map: map,
                    layerInfos: legendLayers,
                    arrangement: esri.dijit.Legend.ALIGN_RIGHT
                }, "legendDiv");
                legend.startup();
            map.addLayers([dynamicLayer, referenceLayer]);
                //add check boxes
                dojo.forEach(legendLayers, function (layer) {
                    var layerName = layer.title;
                    var checkBox = new dijit.form.CheckBox({
                        name: "checkBox" + layer.layer.id,
                        value: layer.layer.id,
                        checked: layer.layer.visible,
                        onChange: function (evt) {
                            var clayer = map.getLayer(this.value);
                            clayer.setVisibility(!clayer.visible);
                            this.checked = clayer.visible;
                    //add the check box and label to the toc
                    dojo.place(checkBox.domNode, dojo.byId("toggle"), "after");
                    var checkLabel = dojo.create('label', { 'for': checkBox.name, innerHTML: layerName }, checkBox.domNode, "after");
                    dojo.place("<br />", checkLabel, "after");
        //show map on load
        dojo.addOnLoad(init);
JakeSkinner
I believe the problem may be that you do not have an array created for legendLayers.  Ex:
var legendLayers = [];
Here is the code I was able to get to work with a hosted feature service from ArcGIS.com:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
    <link rel="stylesheet" type="text/css" href="css/layout.css"/>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
      dojo.require("dijit.dijit"); // optimize: load dijit layer
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("dijit.layout.TabContainer");
      dojo.require("esri.dijit.Legend");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("dijit.form.CheckBox")
      var map;
      function init() {
        var initialExtent = new esri.geometry.Extent({"xmin":-8396836.868209211,"ymin":4835062.442691721,"xmax":-8328196.416809216,"ymax":4891396.53253782,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", {
          extent: initialExtent
        var dynamicUrl = "http://services.arcgis.com/Fz6BBJUji5ArUSDM/arcgis/rest/services/Service_Requests/FeatureServer/0";
        var dynamicLayer = new esri.layers.FeatureLayer(dynamicUrl);
        legendLayers.push({ layer: dynamicLayer, title: "Service Requests" });
            //add the legend
                map: map,
            }, "legendDiv");
            legend.startup();
            //add check boxes
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline"
    gutters="false" style="width:100%; height:100%;">
      <div id="header" dojotype="dijit.layout.ContentPane" region="top">
        This is the header section
       <div id="subheader">subheader</div>
      </div>
      <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left">
        <div dojotype="dijit.layout.TabContainer" >
          <div dojotype="dijit.layout.ContentPane" title = "Legend" selected="true">
            <div id="toggle"></div>
            <div id="legendDiv"></div>
          </div>
          <div dojotype="dijit.layout.ContentPane"  title="Tab 2" >
            Content for the second tab
          </div>
        </div>
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" region="center">
      </div>
      <div id="footer" dojotype="dijit.layout.ContentPane" region="bottom" >
        this is the footer section
      </div>
    </div>
  </body>
</html>
JoseSanchez
Hi Jake,
I do have this variable declared.
This same code shows the legend when I use the default Esri map service but does not work when I point to my local map service.
Shows legend:
Does not show legend:
ReneRubalcava
Esri Frequent Contributor
The minimum version of AGS to run the legend from an internal service is 10.0 SP1.
Make sure you at least have SP1 installed or make the service publicly available and it be generated via arcgis.com
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi/legend.htm
If the layer is an ArcGISDynamicMapServiceLayer or ArcGISTiledMapServiceLayer created using ArcGIS Server 10.0 SP1 or higher the legend is generated using the REST Map Service legend resource.
If the layers are version 10 or lower the legend is created using the ArcGIS.com legend service. In order to use the ArcGIS.com legend service your map service needs to be publicly accessible and your application must be able to access ArcGIS.com.
JoseSanchez
Hi Rene,
You are totally right!!!  After upgrading to the last Service Pack 5 the legend works!!!
Gracias Rene!!!
Saludos
Jose
