Merge two arrays
4479
08-07-2019 07:30 AM
MarkBalman
Hi all
Am struggling to merge two result arrays of species that I wish to display as a single list with no duplicates.
The resulting arrays are in this format:
0: {species_common: "Black Kite"}
1: {species_common: "White Stork"}
How would I go about merging both lists so I can display just the values like Black Kite, White Stork, etc in one list?
I have tried doing this
const object1 = [spcAtObsCommon];
const object2 = [spcAtISitesCommon];
const object3 = {...object1, ...object2 };
if I do a console.log(object3) all I see is the results from object2 in exactly the same format. What am I doing wrong? Any advice or pointers would be gratefully received.
Best,
Mark
MarkBalman
Many thanks for the responses, after some reading around the subject I ended up using the following method..
newArray1 = spcAtObsCommon.map(object => object.species_common);
newArray2 = spcAtISitesCommon.map(object => object.species_common);
console.log([...new Set([...newArray1, ...newArray2])]);
BenElan
Esri Alum
This may work:
let set = new Set();
Object.keys(spcAtISitesCommon).forEach((key)=> {
    set.add(spcAtISitesCommon[key].species_common)
Object.keys(spcAtObsCommon).forEach((key)=> {
    set.add(spcAtObsCommon[key].species_common)
A set is essentially a unique array. We are iterating through the objects and adding each species to the set.
Edit: my understanding being that the data is structured like:
const spcAtObsCommon= {
    0: {species_common: "Black Kite"},
by Anonymous User
Not applicable
Hi Mark,
it could be based on which js version you are using and which browser you are trying to support as well.
To just merge the arrays (without removing duplicates)
ES5 version use Array.concat:
var array1 = ["Vijendra","Singh"];var array2 = ["Singh", "Shakya"];var array3 = array1.concat(array2); // Merges both arrays// [ 'Vijendra', 'Singh', 'Singh', 'Shakya' ]
ES6 version use destructuring
const array1 = ["Vijendra","Singh"];const array2 = ["Singh", "Shakya"];const array3 = [...array1, ...array2];
Since there is no 'built in' way to remove duplicates (ECMA-262 actually has Array.forEach which would be great for this), we have to do it manually:
Array.prototype.unique = function() {    var a = this.concat();    for(var i=0; i<a.length; ++i) {        for(var j=i+1; j<a.length; ++j) {            if(a[i] === a[j])                a.splice(j--, 1);        }    }     return a;};
Then, to use it:
var array1 = ["Vijendra","Singh"];var array2 = ["Singh", "Shakya"];// Merges both arrays and gets unique itemsvar array3 = array1.concat(array2).unique();
This will also preserve the order of the arrays (i.e, no sorting needed).
Since many people are annoyed about prototype augmentation of Array.prototype and for inloops, here is a less invasive way to use it:
function arrayUnique(array) {    var a = array.concat();    for(var i=0; i<a.length; ++i) {        for(var j=i+1; j<a.length; ++j) {            if(a[i] === a[j])                a.splice(j--, 1);        }    }     return a;}var array1 = ["Vijendra","Singh"];var array2 = ["Singh", "Shakya"];    // Merges both arrays and gets unique itemsvar array3 = arrayUnique(array1.concat(array2));
For those who are fortunate enough to work with browsers where ES5 is available, you can use Object.defineProperty like this:
Object.defineProperty(Array.prototype, 'unique', {    enumerable: false,    configurable: false,    writable: false,    value: function() {        var a = this.concat();        for(var i=0; i<a.length; ++i) {            for(var j=i+1; j<a.length; ++j) {                if(a[i] === a[j])                    a.splice(j--, 1);            }        }         return a;    }});
Below is the list for your reference.
JavaScript Array concat() Method
How to merge two arrays in JavaScript and de-duplicate items - Stack Overflow
https://www.samanthaming.com/tidbits/49-2-ways-to-merge-arrays
Array.prototype.concat() - JavaScript | MDN
MarkBalman
