Merge several polygon in Javascript
5512
6
07-14-2020 05:35 AM
rsharma
I want to merge random polygons placed on a graphics layer make a single polygon with only one boundary. Also how to unmerge them.
rsharma
I think this function works for only intersected boundaries: i used the solution below, and it is working fine.
merge.addEventListener('click',function(){
var updatedGeometry=new Array();
graphicsLayer.graphics.map(function(gra){
updatedGeometry.push(new Polygon((gra.geometry)));
var joinedPolygons = geometryEngine.union(updatedGeometry);
graphicsLayer.removeAll();
joinedPolygons.rings.forEach(function(ring)
resultpolygon={type:"polygon",rings:[ring]};
var resultgraphic =new Graphic({
geometry: resultpolygon,
symbol: resultsymbol
graphicsLayer.add(resultgraphic);
// console.log(ring);
RobertScheitlin__GISP
Merge/Union: https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-geometryEngine.html#unio...
To un-merge you loop though the Polygons rings and copy those ring arrays to another Polygon class.
rsharma
hi robert,
long time to hear from your side... how are you, well thanks for the reply, i already get the union link, but couldn't find any example,  if u have any link then pls send..
like i have found this
Merge Polygons in JavaScript API 4.14
Do, i need to to loop through all the polygons of a layer, to get its graphics geomtrry
Correct. The Union works with the actual geometry not the layer.
rsharma
jQuery('#main').on('click','.merge_boundary',function(){
updatedGeometry.push(webMercatorUtils.webMercatorToGeographic(gra.geometry));
var joinedPolygons = geometryEngine.union(updatedGeometry);//it returned all  polygons as it is, do not merge to make it one
console.log(joinedPolygons.rings);
addGraphics(joinedPolygons.rings);
Rajni,
   This is better code. See if this helps.
  var updatedGeometry = graphicsLayer.graphics.map(function(gra){
    return webMercatorUtils.webMercatorToGeographic(gra.geometry);
rsharma
