Measurement Widget Help
5281
01-30-2015 11:16 AM
BrianPaulson1
I am trying to insert the measurement widget to a project I am working on.  Below is my project code from another example.  How do I get the measurement tool added to the map?  I have followed the example here:Measurement | ArcGIS API for JavaScript , but I must be doing something wrong since the tool doesn't load.  Sorry I am a new to arcgis javascript and I am probably missing something basic.  Thanks
    <!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the
    samples on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Flickr</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dojo/resources/dojo.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dgrid/css/dgrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
      .dgrid { border: none; height: 100%; }
      .dgrid-column-0 {
        width: 35px;
      .dgrid-row-odd {
        background: #FFFDF3;
      td div img:hover {
        cursor: pointer;
    </style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map, grid;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/dijit/PopupTemplate",
        "esri/request",
        "esri/tasks/query",
        "esri/geometry/Point",
        "esri/graphic",
        "dojo/on",
        "dojo/_base/array",
        "dgrid/OnDemandGrid", "dgrid/Selection", "dojo/store/Memory",
        "dijit/form/Button",
        "dojo/parser", "dojo/_base/declare",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Query,
        Point,
        Graphic,
        on,
        array,
        Grid, Selection, Memory,
        Button,
        parser, declare
        var featureLayer;
        map = new Map("map", {
          basemap: "satellite",
          center: [-46.807, 32.553],
          zoom: 3
        //create a feature collection for the flickr photos
        var featureCollection = {
          "layerDefinition": null,
          "featureSet": {
            "features": [],
            "geometryType": "esriGeometryPoint"
        featureCollection.layerDefinition = {
          "geometryType": "esriGeometryPoint",
          "objectIdField": "ObjectID",
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "url": "images/flickr.png",
                "contentType": "image/png",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "alias": "ObjectID",
            "type": "esriFieldTypeOID"
            "name": "title",
            "alias": "Title",
            "type": "esriFieldTypeString"
        //define a popup template
        var popupTemplate = new PopupTemplate({
          title: "{title}",
          description: "{description}"
        //create a feature layer based on the feature collection
        featureLayer = new FeatureLayer(featureCollection, {
          outFields: ["*"],
          infoTemplate: popupTemplate
        //associate the features with the popup on click
        featureLayer.on("click", function(evt) {
          map.infoWindow.setFeatures([evt.graphic]);
        map.on("layers-add-result", function(evt) {
          requestPhotos();
        //add the feature layer that contains the flickr photos to the map
        map.addLayers([featureLayer]);
      function requestPhotos() {
        //get geotagged photos from flickr
        //tags=flower&tagmode=all
        var requestHandle = esriRequest({
          url: "http://api.flickr.com/services/feeds/geo?&format=json",
          callbackParamName: "jsoncallback"
        requestHandle.then(requestSucceeded, requestFailed);
      function requestSucceeded(response, io) {
        //loop through the items and add to the feature layer
        var features = [];
        array.forEach(response.items, function(item) {
          var attr = {};
          attr["description"] = item.description;
          attr["title"] = item.title ? item.title : "Flickr Photo";
          var geometry = new Point(item);
          var graphic = new Graphic(geometry);
          graphic.setAttributes(attr);
          features.push(graphic);
        var items = array.map(features, function(feature) {
              return feature.attributes;
        featureLayer.applyEdits(features, null, null, function(){
        var dataGrid = declare([Grid, Selection]);
          var columns = [{
            label: "",  //wasn't able to inject an HTML <div> with image here
            field: "ObjectID",
            formatter: makeZoomButton
            label: "Title",
            field: "title"
          grid = new dataGrid({
            bufferRows: Infinity,
            columns: columns
          }, "grid");
          var memStore = new Memory({
            data: items,
            idProperty: "ObjectID"
          window.grid.set("store", memStore);
          window.grid.set("sort", "ObjectID");
          grid.on(".field-ObjectID:click", function(e) {
            //retrieve the ObjectId when someone clicks on the magnifying glass
            if (e.target.alt) {
              zoomRow(e.target.alt);
      function requestFailed(error) {
        console.log('failed');
      function makeZoomButton(id) {
          var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='images/zoom.png' alt='" + id + "'";
          zBtn = zBtn + " width='18' height='18'></div>";
          return zBtn;
      function zoomRow(id) {
        featureLayer.clearSelection();
        var query = new Query();
        query.objectIds = [id];
        featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features) {
          //zoom to the selected feature
          if(features && features.length > 0){
            var feature = features[0]; //get the first feature
            map.centerAndZoom(feature.geometry, 10);
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" >
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:275px">
      <div id="grid"></div>
     </div>
    </div>
  </body>
</html>
JakeSkinner
Esri Esteemed Contributor
Hi Brian,
Here is an update to the code that implements the Measurement widget.
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
      .dgrid-column-0 {
        width: 35px;
      .dgrid-row-odd {
      td div img:hover {
        cursor: pointer;
      #titlePane{
        width:240px;
      .claro .dijitTitlePaneTitle {
        background: #fff;
        font-weight:600;
        border: none;
        border-bottom:solid 1px #29201A;
        border-top:solid 1px #29201A;
      .claro .dijitTitlePaneTitleHover {
        background:#eee;
      .claro .dijitTitlePaneTitleActive {
        background:#808775;
      .claro .dijitTitlePaneContentOuter {
        border-right: none;
        border-bottom: none;
        border-left: none;
    </style>
    <script>
      var map, grid;
      require([
        "esri/map",
        "esri/dijit/Measurement",
        "esri/request",
        "esri/tasks/query",
        "esri/graphic",
        "dojo/on",
        "dojo/_base/array",
        "dojo/parser", "dojo/_base/declare", "dojo/dom",
        "dijit/TitlePane", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map,
        Measurement,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Query,
        Point,
        Graphic,
        on,
        array,
        Button,
        parser, declare, dom
        parser.parse();
        var featureLayer;
          zoom: 3
          "featureSet": {
            "features": [],
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "name": "title",
            "alias": "Title",
          title: "{title}",
          outFields: ["*"],
          requestPhotos();
        var features = [];
          var attr = {};
          var columns = [{
            field: "ObjectID",
            label: "Title",
            field: "title"
            columns: columns
          }, "grid");
            data: items,
            if (e.target.alt) {
          return zBtn;
      var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
      measurement.startup();
    </script>
  </head>
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
        </div>
      </div>
     </div>
    </div>
  </body>
</html>
JakeSkinner
Hi Brian,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
      .dgrid-column-0 {
        width: 35px;
      .dgrid-row-odd {
      td div img:hover {
        cursor: pointer;
      #titlePane{
        width:240px;
        background: #fff;
        font-weight:600;
        border: none;
        background:#eee;
        background:#808775;
        border-right: none;
        border-left: none;
    </style>
    <script>
      var map, grid;
      require([
        "esri/map",
        "esri/request",
        "esri/tasks/query",
        "esri/graphic",
        "dojo/on",
        "dojo/_base/array",
        "dojo/domReady!"
      ], function(
        Map,
        Measurement,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Query,
        Point,
        Graphic,
        on,
        array,
        Button,
        parser.parse();
        var featureLayer;
          zoom: 3
          "featureSet": {
            "features": [],
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "name": "title",
            "alias": "Title",
          title: "{title}",
          outFields: ["*"],
          requestPhotos();
        var features = [];
          var attr = {};
          var columns = [{
            field: "ObjectID",
            label: "Title",
            field: "title"
            columns: columns
          }, "grid");
            data: items,
            if (e.target.alt) {
          return zBtn;
          map: map
    </script>
  </head>
          </div>
        </div>
      </div>
     </div>
    </div>
  </body>
</html>
TimWitt2
Jake Skinner‌ you are no fun I was just about to post
JakeSkinner
Tim Witt‌, I hate it when that happens.  At least it's Friday, and happy hour is only a couple hours away
