Measure Widget Units precision on different locale
739
03-27-2017 09:03 AM
JoseMachado
When using the Measure Widget the value resulting from using Nautical Miles differs if i'm using the "pt-pt" locale.
When i use the widget with the default locale (en) the result is "12,5 nautical miles" but if i change to "pt-pt" the same result is "0,01 milhas náuticas"
As anyone experienced something similar and where can i quick fix this ?
JM
