Marker Symbol help me please
1108
08-06-2013 08:13 AM
LouPhan
I want to change the symbol of below example into this code. However, it could not display the new symbol. Can someone help me?
symbol = new esri.symbol.PictureMarkerSymbol({
"angle": 0,
"xoffset": 0,
"yoffset": 12,
"type": "esriPMS",
"url": "http://static.arcgis.com/images/Symbols/Basic/YellowStickpin.png",
"contentType": "image/png",
"width": 24,
"height": 24
Here is the example:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>QueryTask with value, results as an InfoWindow</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
    <script type="text/javascript" language="Javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.query");
      var map, queryTask, query;
      var symbol, infoTemplate;
      function init() {
        //create map
       map = new esri.Map("mapDiv");
    // var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
         //     map.addLayer(basemap);
        //create and add new layer
        var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer");
        map.addLayer(layer);
        //build query task
        queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0");
        //build query filter
        query = new esri.tasks.Query();
        query.returnGeometry = true;
        query.outFields = ["CITY_NAME", "STATE_NAME", "POP1990"];
        //create the infoTemplate to be used in an InfoWindow.
        //All ${attributeName} will be substituted with the attribute value for current feature.
        infoTemplate = new esri.InfoTemplate("${CITY_NAME}", "Name : ${CITY_NAME}<br/> State : ${STATE_NAME}<br />Population : ${POP1990}");
  //create symbol for selected features
  symbol = new esri.symbol.SimpleMarkerSymbol();
  symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
  symbol.setSize(10);
  symbol.setColor(new dojo.Color([255,255,0,0.5]));
   function executeQueryTask(population) {
        //set query based on what user typed in for population;
  query.where = "POP1990 > " + population;
        //execute query and call showResults on completion
        queryTask.execute(query,showResults);
      function showResults(featureSet) {
        //remove all graphics on the maps graphics layer
        map.graphics.clear();
        //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the map.
  //Performance enhancer - assign featureSet array to a single variable.
  var resultFeatures = featureSet.features;
        for (var i=0, il=resultFeatures.length; i<il; i++) {
          //Get the current feature from the featureSet.
          //Feature is a graphic
          var graphic = resultFeatures;
          graphic.setSymbol(symbol);
          //Set the infoTemplate.
          graphic.setInfoTemplate(infoTemplate);
          //Add graphic to the map graphics layer.
          map.graphics.add(graphic);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
  <br/>
      US city population greater than : <input type="text" id="population" value="500000" />
    <input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('population').value);" />
    <div id="mapDiv" style="width:600px; height:600px; border:1px solid #000;"></div>
 Click on a city once it's highlighted to get an InfoWindow.
  </body>
</html>
Here is my change. It is not working:
<html>
  <head>
      function init() {
        //create map
        //build query task
                "angle": 0,
                "xoffset": 0,
                "yoffset": 12,
                 "type": "esriPMS",
                "width": 24,
                "height": 24
    </script>
  </head>
  <br/>
  </body>
</html>
LuciHawkins
Hey,
I think you are trying to use the syntax for javascript api v3.5.  You need to use the syntax from the javascript api v1.6 that you are calling out in your app.
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jsapi_start.htm
This code worked in your app:
symbol = new esri.symbol.PictureMarkerSymbol('http://static.arcgis.com/images/Symbols/Basic/YellowStickpin.png', 24, 24);
Hope this helps!
Luci
