I'm trying to verify that the rotationEnabled constraint when set to false for a 2D MapView in 4.7 is not being applied on mobile devices. The issue appeared to be fixed in prior to this release and corrected a pinch to zoom problem, but I noticed this morning that the constraint is set to false and the map still rotates on mobile.
Just to confirm, are you still experiencing the issue in 4.8 as well?
Yes, I'm still seeing the issue using 4.8.
Hi Beth,
Thanks for the quick reply. We had a bug come in that was very similar to this. I'm not sure if it is the same thing though. It appeared to be addressed at 4.8, hence we initially asking that. Are you doing something similar to this in your code?
CodePen - A Pen by Heather Gonzago
Can you see if this rotates for you. If so, what device are you using and what browser?
Hi Heather,
Yes, your map rotates on an iPad Pro (Safari, iOS 11.4) but not on an iPhone (Safari, iOS 11.4.1).
Thanks for checking Beth. I just rechecked on a couple of devices and do see the same behavior. It is related to an existing bug, BUG-000113862. Thanks for catching that and letting us know.
Just wanted to let you know that this bug has been fixed for our next 4.9 release.
Thanks for bringing it to our attention.
Heather
