Mapservice for ESRI's Javascript API Buffer Any Shape Example
3083
11
03-20-2014 11:07 AM
MichaelVolz
Esteemed Contributor
To All Javascript API Developers:
The following URL is the link to ESRI's Javascript API Buffer Any Shape Example
https://developers.arcgis.com/javascript/jssamples/util_buffergraphic.html
I downloaded the source code to my computer to modify the example so it would use my organization's AGS service.  I was able to find the geometry service to perform the buffer operation, but I cannot find the mapservice for this sample in the source code.
Would anyone know where the mapservice is coming from for this example?
JakeSkinner
Esri Esteemed Contributor
jsfiddle is an online testing area for your javascript/html/css, not really an IDE.  I usually recommend Aptana.  This is a free IDE you can download.
MichaelVolz
Can you just load a sample script, such as the ESRI Buffer example, into jsfiddle and it will automatically separate the code into the proper components (e.g. HTML, CSS, and Javascript)?  This is what I did with the example but all the code was placed in the HTML section and when I hit run, nothing happened.
