Mapserver not found
6896
13
12-11-2018 06:57 AM
EbunoluwaAkingbaso
After installing JavaScript API and SDK , i tried to test my  installation but it throws the error - MapServer not found. Actually arcgis/rest/services/Folder/Custom_Base_Map/MapServer was not found. I don't know if i have done something wrong. Please what could be the solution to this error. Thanks
EbunoluwaAkingbaso
Secure Connection Failed
An error occurred during a connection to eif-gis-serv.eifer.kit.edu:6080. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
RobertScheitlin__GISP
Your ArcGIS Server is not installed correctly and I am not sure what to tell you now. You will need to contact esri tech support and get you server installation fixed.
EbunoluwaAkingbaso
Ok. Thank you
EbunoluwaAkingbaso
I feel so, because i am finding it difficult to publish 3D building..it successfully publish but cache failed. I guess the arcgis server is also affecting that..
