MapImageLayer search widget
3460
9
02-09-2022 06:56 AM
KristianTuusjärvi
Hello, is it possible to search from all of the MapImageLayer sublayers?
Should I use a collection of LayerSearchSource to iterate through all of the sublayers and then add the collection to Search widget's 'sources' property.
const sources = new Collection<LayerSearchSource>();
//Loop through MapImageLayer and add to sources??
const search = new Search({
view: view,
  sources: sources,
Noah-Sager
Hi @KristianTuusjärvi, yes, you can use a Sublayer just like a FeatureLayer as a LayerSearchSource.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search-LayerSearchSource....
I would recommend pulling out all the sublayers first, then add them as a LayerSearchSource individually so you can configure the settings like in this sample:
https://developers.arcgis.com/javascript/latest/sample-code/widgets-search-multiplesource/
KenBuja
MVP Esteemed Contributor
That sample is unreachable, but are there any updates to the existing sample?
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-search-multiples...
Noah-Sager
Thanks @KenBuja. I updated the link. No updates to report.
nadja
Hi @Noah-Sager
I'm not sure if the sample code has been modified, but there is no sample of a sublayer of a MapImageLayer in above sample code. I'm wondering how do you "pull out all the sublayers first"? Thank you for your answer.
@KristianTuusjärvi Have you managed to include the entire MapImageLayer as a source to Search?
Best,
Nadja
Noah-Sager
Correct @nadja, the sample I linked to shows how to set-up individual feature layers for use with the LayerSearchSource, like for example the searchFields and the outFields. It wouldn't work with just adding all Sublayers from a MapImageLayer without knowing more about the Sublayers. Does that make sense? So I don't think a programmatic approach would simplify things. I would just add the the Sublayers as individual LayerSearchSources.
nadja
Yes, thanks @Noah-Sager, this makes sense. However, I wonder how I would add the Sublayers as individual LayerSearchSource? Let's take the first Sublayer as an example. I tried several approaches to access the first Sublayer:
const MyLayerSearchSource= new LayerSearchSource({
  layer: MyMapImageLayer.findSublayerById(0)
const searchWidget = new Search({
    view: view,
    sources: [{
        layer: search_perimeter,
        searchFields: ["*"],
        outFields: ["*"]
This code-snippet throws the error "Uncaught (in promise) TypeError: a.load is not a function". How do I access the sublayer correctly?
Noah-Sager
Yeah, unfortunately you can't load a Sublayer directly, it needs to be a FeatureLayer or one of the other approved layer types in the doc: https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#sources
What you can do is flatten the collection of Sublayers in the MapServer, then create FeatureLayers (and get the relevant LayerSearchSource attributes) out of each Sublayer.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-MapImageLayer.html#allSubl...
You should be able to also use the Sublayer.createFeatureLayer() method, but I had trouble with the synchronicity of the requests.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-Sublayer.html#crea...
After creating the FeatureLayer and the LayerSearchSource attributes, add them to an object, and then add that object to the Search widget sources Collection.
Here is a proof-of-concept app that should help clarify a potential workflow:
https://codepen.io/noash/pen/VwxgQzv?editors=1000
Try searching for a simple word here, like "new" or "yo".
KristianTuusjärvi
I wonder if I can just add the whole MapImageLayer as a source to Search? It seems to be possible, but I don't understand how to choose the fields when there is multiple sublayers on MapImageLayer.
Here it is mentioned that MapImageLayer can be used. Any ideas?
Noah-Sager
Sorry @KristianTuusjärvi, I just noticed this question. Unfortunately, MapImageLayer is not listed there. Perhaps we could improve the wording to make this more clear. What it means is that a FeatureLayer from a MapServer or a FeatureServer is usable. So if you had a MapServer like this:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer
You could also just use each Sublayer URL (effectively consuming it as a FeatureLayer) as a source for the Search widget:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/1
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3
