Map zooming to full size of html div on load.
1398
07-04-2013 05:49 AM
sudhirkulkarni
Follwing is my html/javascript , on start it should open the map in full div but instead it open in a small size.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>Create Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      function init() {
        var initExtent = new esri.geometry.Extent(8.3715,58.6010, 34.7387,98.15185, new esri.SpatialReference({ wkid:4326 }));
        map = new esri.Map("map",initExtent );
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        dojo.connect(map, 'onLoad', showfunct);
      function showfunct(){
          var points = {
          "points": [[70.8258,18.5141],[71.56134,18.554551] ],
          "spatialReference": ({ "wkid": 4326 })
          var mp = new esri.geometry.Multipoint(points);
          var wm_mp = esri.geometry.geographicToWebMercator(mp);
          var sms = new esri.symbol.SimpleMarkerSymbol();
          var infoTemplate = new esri.InfoTemplate("Vernal Pool Locations", "");
          var graphic = new esri.Graphic(wm_mp, sms, '', infoTemplate);
          map.graphics.add(graphic);
      dojo.ready(init);
    </script>
  </head>
  <body class="tundra">
    <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div>
    <div id="info" style="padding:5px; margin:5px; background-color:#eee;"></div>
  </body>
</html>
BenFousek
Your map object is not formed correctly. Map options follow the map div in curly brackets as pairs.
See https://developers.arcgis.com/en/javascript/jsapi/map.html for more on map options.
Like this:
map = new esri.Map("map", { extent: initExtent } );
P.S. please wrap code and html in tags. Select text in editor and click the appropriate button. See attached.[ATTACH=CONFIG]25729[/ATTACH]
