Map Service not loading using Javascript API
2087
01-28-2011 09:00 AM
VinayVyas
I have a local ArcGIS server using which I published a service.
The service works using the "Create a Web Application" Wizard.
I downloaded a sample code and it ran smoothly, the difference is the URL is online and not local to my server.
I want to run this code using my local ArcGIS server URL and all I see is a blank screen. The map is error free. Can anybody help resolve this?
My code
<html>
<head>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1" type="text/javascript"></script>
<link href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css" rel="stylesheet" type="text/css" >
</head>
<script type="text/javascript">
  dojo.require("esri.map");
var map;'
function init()
map=new esri.Map("mapDiv")
var basemapURL = "http://8hXXXX:8399/arcgis/rest/services/Map_City/MapServer";
var basemap = new esri.layers.ArcGISDynamicMapServiceLayer(basemapURL);
map.addLayer(basemap);
dojo.addOnLoad(init);
</script>
<body class="caro">
<div id="mapDiv" style="width:900px;height:600px;border:1px solid #000;"></div>
</body>
</body>
</html>
Thanks!
PS: URL no is censored for security
HemingZhu
My code
<html>
<head>
</head>
var map;'
function init()
</script>
<body class="caro">
</body>
</body>
</html>
Thanks!
can you view your service in a browser using http://8hXXXX:8399/arcgis/rest/services/Map_City/MapServer?
JohnHaddad
I can think of 3 possibilities:
1. Your service is cached and you are using the ArcGISDynamicMapServiceLayer directive which is for dynamic map services.
2. You are using a reverse proxy (I noticed that you are using a non-standard port) and it is not configured correctly. See http://resources.arcgis.com/content/kbase?fa=articleShow&d=32634 for more info.
3. I see a small typo in your code (space in the variable name 'basemapUR L'):
 var basemap = new esri.layers.ArcGISDynamicMapServiceLayer(basemapUR L);
derekswingley1
Also, the class attribute on the body tag should be "claro", not "caro".
