Hey everyone,
I was wondering if there is some way to have a hint next to your mouse cursor when you enter the map area. I know how to fire it, but I don;t know how to create it.
As an example, click on the point or polygon button in this example to see what I mean:
Thanks!
Tim
Tim,
Here is an Updated sample.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Map Tip Sample</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
#map{
padding:0;
.map .tooltip{
position:fixed;
overflow:hidden;
display: block;
color: black;
background-color: #FFFFFF;
border: 1px solid gray;
padding: 5px;
border-radius:4px;
font-size:11px;
font-family:Verdana;
z-index: 9999;
</style>
<script src="http://js.arcgis.com/3.10/"></script>
<script>
var map;
require([
"esri/map",
"dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, parser
parser.parse();
map = new Map("map", {
basemap: "topo",
center: [-105.255, 40.022],
zoom: 13
var tip = "I'm over the map";
var toolTip = dojo.create("div", { "class": "tooltip", "innerHTML": tip}, map.container);
toolTip.style.position = "fixed";
map.on("mouse-move",function (evt) {
var px, py;
if (evt.clientX || evt.pageY) {
px = evt.clientX;
py = evt.clientY;
} else {
px = evt.clientX + win.body().scrollLeft - win.body().clientLeft;
py = evt.clientY + win.body().scrollTop - win.body().clientTop;
toolTip.style.display = "none";
toolTip.style.top = (py + 20) + 'px';
toolTip.style.left = (px + 20) + 'px';
toolTip.style.display = "block";
map.on("mouse-out",function (e) {
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline', gutters:false"
style="width:100%;height:100%;margin:0;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'"
style="padding:0;" />
</div>
</body>
</html>
Tim,
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<style>
#map{
padding:0;
.map .tooltip{
position:fixed;
overflow:hidden;
display: block;
color: black;
padding: 5px;
border-radius:4px;
font-size:11px;
z-index: 9999;
</style>
<script>
var map;
require([
"esri/map",
"dojo/parser",
"dojo/domReady!"
], function(
Map, parser
parser.parse();
basemap: "topo",
zoom: 13
var px, py;
px = evt.clientX;
py = evt.clientY;
} else {
</script>
</head>
<div id="map"
</div>
</body>
</html>
Hey Robert,
after some testing I noticed that some parts of the map act funky once I hover over the map.
For example on the bottom right over the ESRI logo, text starts popping up and when I open the basemap layer tab, depending if my mouse is over the map or not text appears and disappears.
What could cause that?
Tim
Tim,
Sorry I did not notice that when I threw together the sample. The one you found works great just needs to be updated to AMD.
No worries, you pointed me in the right direction. Not to mention, I would be happy, if I could just throw something like this together!
And yes you are right, I had to "translate" it into AMD. Don't want that pesky Legacy around ![]()
| var tip = "Click the map to get an address!"; | |||
| var tooltip = domConstruct.create("div", { "class": "tooltip", "innerHTML": tip }, map.container); | |||
| domStyle.set(tooltip, "position", "fixed"); | |||
| var toolFunc = map.on("mouse-move", function(evt){ | |||
| var px, py; | |||
| if (evt.clientX || evt.pageY) { | |||
| px = evt.clientX; | |||
| py = evt.clientY; | |||
| } else { | |||
| px = evt.clientX + win.body().scrollLeft - win.body().clientLeft; | |||
| py = evt.clientY + win.body().scrollTop - win.body().clientTop; | |||
| // dojo.style(tooltip, "display", "none"); | |||
| tooltip.style.display = "none"; | |||
| domStyle.set(tooltip, { left: (px + 15) + "px", top: (py) + "px" }); | |||
| // dojo.style(tooltip, "display", ""); | |||
| tooltip.style.display = ""; | |||
| // console.log("updated tooltip pos."); | |||
| map.on( "mouse-out", function(evt){ | |||
I updated my sample for those who view it in the future.
I marked it as answer since it is in AMD, thanks!
