Map.graphics.add() not showing points on the map
11636
16
11-13-2013 10:25 AM
IrfanClemson
I have inherited an ArcGIS JavaScript API project. I am very new to this API in particular and ArcGIS in general. Currently, one part of the code is very problematic--populating the map with some query task's results. Here is a code snippet. In the debugger I can see the returned results, including geometry of individual result rows. But they never show up on the map.
  function showResults(results) {//This bounds the results into the data grid from doFind() function      var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 200), new dojo.Color([98,194,204,0.5]));       for(var i=0; i < results.features.length; i++){        //map.graphics.add(results.features);     var graphic = results.features;     graphic.setSymbol(symbol);     map.graphics.add(graphic);      }              }
What could be happening? I don't think posting thousands of line of code will help. But the debugger does show information for each row, such as:
map.graphics.graphics.geometry[0]->
- _shape=null
- type=point
- x= 283265
- y= 3955658
- symbol [object data]
and when I go to:
http://myserver/arcgis/rest/services/NPS_Location_Search/MapServer/0
then, under Drawing Info, I can see the colored dot object for Symbol.
I can give more info about how the various maps are laid out if that helps?
Thanks!
Meengla
ReneRubalcava
Esri Frequent Contributor
You mway want to make sure the results are in the proper spatial reference.
Make sure you have this in your code some where before executing the QueryTask.
query.outSpatialReference = map.spatialReference;
https://developers.arcgis.com/en/javascript/jsapi/query-amd.html#outspatialreference
This has bitten me on more than one occasion.
ReneRubalcava
IrfanClemson
@Odoe,
I just put the line query.outSpatialReference = map.spatialReference;
before query.execute function and now get an error like '_3db undefined'; this error's stack seems to be from:
require({cache:{"esri/layers/TimeReference":function(){define(["dojo/_ ...
I did put a dojo.require("esri.SpatialReference"); toward the top of the javascript file--where other 'require' are but still the same error.
I will research the cause of this latest problem... If someone knows then please save me some time--it's been enough struggle with this already.
Thanks!
KaitlynnDavis
Your graphics might actually be getting added. I would recommend commenting out the map.spatialReference line that is giving you the error statement just for now and run your code, then try to zoom as far away as possible. Your point graphics might be appearing in a whole other part of the globe, in which case you then know for sure that you have a projection issue
IrfanClemson
@Kait,
Okay, I commented out the
query.outSpatialReference =  map.spatialReference;//
line and then did the query and then zoomed out--and once I tried to zoom out of the extents of the US continental (the lower 48) I saw the same error as above: '_3eb undefined';
so even though the query.outSpatialReference is commented out I am getting the same error.
I tend to agree with you and @Odoe that this is some extent issue?
Thanks!
vinayb
I am getting exactly the same problem , map.graphics.add() is not showing the gaphics.
I had to change my code to from queryTask.execute() to esri.requst i am faicng this issue ever since.
my query had below condition:
var qTask= new QueryTask(queryTaskUrl);
            var query = new Query();
            query.returnGeometry = true;
            query.maxAllowableOffset = 4326;
            query.where = executableQuery;
            query.spatialRelationship = Query.SPATIAL_REL_CONTAINS;
            var spRef = new esri.SpatialReference({
                wkid: 102100
            query.outSpatialReference = spRef
hence i changed my code to
                wkid: 102100
   var queryRequest = esriRequest({
      url : queryTaskUrl,
      content : {
       f : "json",
     returnGeometry: true,
     where : executableQuery,
     outSR:spRef ,
     maxAllowableOffset:4326,
     spatialRel:"esriSpatialRelContains"
      callbackParamName : "callback"
     }, {usePost : true});
   handleAs : "json",
    queryRequest.then(showResults, function (error) {
     console.log("Error: ", error.message);
var color="#919191";
        try {
            var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color("#AED8EC"), 1), new Color(color));
            dojo.forEach(featureSet.features, function(feature){
                console.log(" iterating each feaures " +feature);
    //var graphic = new FeatureSet(feature);
    var graphic=new FeatureSet(feature);
    //var graph = new Graphic(graphic);
    graphic.setSymbol(symbol );
    console.log(" graphic feaures " +graphic.symbol.color);
    console.log(" graphic visible " +graphic.visible);
        catch (e) {
            console.log(" issue in iterator " + e);
now map.graphics.add() does not show up
but when i change
belwo line
outSR:map.spatialReference
graphics shows but it not exactly as expected hence how do i know what is exact valuel
IrfanClemson
@VinayBa,
I tried to changed to your code but in the showResults function I am only getting field names in the results--not actual data. If I could get featuresets then maybe the symbols would at least show--as in your case.
I may have to recreate this application--it has so many problems and for someone like me who is barely getting started there are too many fires to put out during the learning process.
Thanks.
vinayb
Sorry my  code is not solution to ur problem ,  i have same problem as yours .But for your problem check from desktop tool the projection  sysrtem and spatialrefrence to use.
JeffPace
what type of geometry are you returning?
Your Subject says "points" but your code is using a fill symbol, which is polygon
IrfanClemson
Sorry, I don't understand. What should I tell the person who published the .mxd to the server to change and republish?
