Map Cursor
1137
12-27-2011 09:43 AM
VIKRANTKRISHNA
Does anyone know how to set custom map cursor in IE9? This line of code doesn't work for me
map.setMapCursor("url(cursors/property.cur)");
VIKRANTKRISHNA
I found the solution. It was the compatibility mode option in IE causing the problem.
VIKRANTKRISHNA
I found the solution. It was the compatibility mode option in IE9 causing the problem.
