Map Components - Widget Components without a Map or Scene
1036
07-26-2024 06:07 AM
Justin_Greco
Is it possible to use a widget component, such as arcgis-search without an arcgis-map component?  It looks like the widgets have to be wrapped inside of arcgis-map.  Are there plans to be able to use the widgets without a map or scene?
The use case is a widget that we have in a web component on our website that allows users to enter their address in the search widget and then display feature widgets for the results, without a map.
Tags (1)
ReneRubalcava
Esri Frequent Contributor
Thanks, we'll be taking a look at this for the next release. Oversight.
ReneRubalcava
