make a field required in the attributeInspector with fieldInfos
1803
11-05-2014 02:20 PM
ShaneLim
How do I make a specific field required in the attributeInspector within the fieldInfos setup I would think.
var layerInfos = [{
                    'featureLayer': featureLayer,
                    'showAttachments': false,
                    'showDeleteButton': true,
                    'fieldInfos': [
                        { 'fieldName': 'OBJECTID', 'label': 'ObjectID' },
                            'fieldName': 'INSSTART', 'label': 'Flow Time', "format": {
                                "time": true
                        { 'fieldName': 'STATICPSI', 'label': 'Static (PSI)' },
                        { 'fieldName': 'RESIDUALPSI', 'label': 'ResidualPSI' },
                        { 'fieldName': 'PITOT', 'label': 'Pitot' },
                        { 'fieldName': 'OUTLETDIAMETER', 'label': 'Outlet Diameter' },
                        { 'fieldName': 'FLOWMINUTE', 'label': 'Flow Minute' },
                        { 'fieldName': 'INSPECTOR', 'label': 'Flowed By' },
                        { 'fieldName': 'NOTES', 'label': 'Notes' },
                        { 'fieldName': 'FACILITYKEY', 'label': 'Hydrant ID' },
                        { 'fieldName': 'CALCFLOW20PSI', 'label': 'CalcFlow20PSI' },
                        { 'fieldName': 'FLOW', 'label': 'Flow Rate (GPM)' },
                        { 'fieldName': 'LASTUPDATE', 'label': 'Last Update Date' },
                        { 'fieldName': 'INSPECTID', 'label': 'InspectionNumber' }
var attributeInspector = new AttributeInspector({ layerInfos: layerInfos }, "attributeDiv");
RobertKirkwood
