Looking for samples of Toolbars
3187
6
08-21-2013 04:12 AM
JoseSanchez
Hi all
Anyone can recommend a sample of toolbar with buttons and commands?
thanks
VinayBansal
BenFousek
Are you looking for a toolbar that you can add your own buttons and such to?
If so, dijit/Toolbar is what you are looking for. http://dojotoolkit.org/reference-guide/1.9/dijit/Toolbar.html#dijit-toolbar
Attached are a couple images from an application with tabbed toolbars.  All the buttons and such are added programmatically when the application loads.  A single toolbar works great as the top region of a BorderContainer.
[ATTACH=CONFIG]26868[/ATTACH][ATTACH=CONFIG]26869[/ATTACH]
If this what you are looking for and need code snippets I can post.
LucasYuim
I like to use the social buttons too in the toolbars of my websites, this site have really good pluggins:
http://www.addthis.com/
JoseSanchez
I am using the toolbar from this sample: http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jssamples_start.htm#jssa...
what I need is to add some additional buttons such as:
- the identity button or select by point
- select by rectangle
- select by circle
- find address button that opens a popup window
- etc ...
Any samples that might help?
BenFousek
Here's a fiddle.
Looks better in full screen.
This example has a toolbar as the top region of a border container showing both declarative and programmatic methods for adding buttons, etc.
LeandroVin
To me the Draw Toolbar was handful. You should try it.
