Loading Local Esri Modules via AMD
1788
6
08-07-2012 06:17 AM
ScottDavis
Just wondering if it's possible to load locally hosted Esri modules via AMD rather than loading the entire jsapi layer file. I'd like to use my own version of dojo.js and just load the individual Esri modules. Here's my attempt on GitHub: https://github.com/stdavis/EsriPackageDemo but it's not working yet. Hoping that someone might have some ideas.
derekswingley1
This not currently possible as our modules are not fully AMD compliant (yet).
ScottDavis
Shouldn't it be possible using async: false which supports legacy modules defined with dojo.provide?
derekswingley1
It might be possible, but I haven't explored it.
Have you seen the examples linked from here:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/inside_dojo_amd.html
ScottDavis
Yes, I've seen those but they are using Esri's layer file (which includes dojo base). Would love to see an example of how to use Esri modules without loading the layer file.
derekswingley1
AFAIK, that's not possible without an un-built version of the API source.
ScottDavis
That's what I was afraid of. 😞
