load map on a popup window
1451
09-05-2014 12:09 PM
BhavinSanghani
I am trying to load following map on a html popup window but it doesn't get displayed. I can see from the page source that HTML 5 code to display map is available within the supplied div. Is there any example to show map on popup window?
Create a map | ArcGIS API for JavaScript
BhavinSanghani
Never mind I could fix it in my code. It was an issue with map div's height/width.
BhavinSanghani
