Link to Popup
8881
35
11-30-2018 10:33 AM
jaykapalczynski
Honored Contributor
I have an info template returning a link.
Right now with I click on it it opens to a new browser tab (_blank)
Looking for 2 options.
1. Display this in a DIV
2. Pop this up into a new floating popup
Any ideas
var infoHighwayCameras = new InfoTemplate();
     infoHighwayCameras.setTitle("Highway Cameras");
     infoHighwayCameras.setContent("<table>" +
     "<tr><td id='tblTitle'>Highway Cameras</td><td id='tblTitle2'></td></tr>" +
     "<tr><td id='tblTitleLine'></td><td id='tblTitleLine2'></td></tr>" +
     "<tr><td></td><td></td></tr>" +
     "<tr><td id='tblMainline1'>image_url</td><td id='tblSubline2'><i>For Camera Image <a href='${image_url}' target='_blank'><font color='0x84CCDA'>click here</font></a>."+
     "</table><hr>");
jaykapalczynski
Honored Contributor
Yea they have a Service
This service has a bunch of features in it.
Each feature has a field called image_url
This URL will NOT change...it will reference the SAME .png file every time.
See Below
This is how I think they do it.
  1. The database value for this field stays constant including the name of the image.
  2. The image is simply replaced on their server in the "thumbs" folder with a new image every few seconds via an upload from the cameras in the field.
I just cant get the InfoTemplate to refresh with the new image.
jaykapalczynski
Honored Contributor
If you click this link you can see that the popup image is replaced... takes about 5-10 seconds for a new image to be taken.
RobertScheitlin__GISP
Jay,
  OK this is what I got working on my end:
    infoHighwayCameras.setContent(getTextContent);
    function getTextContent(graphic) {
      return "<table>" +
        "<tr><td id='tblMainline1'>description</td><td id='tblSubline2'> " + graphic.attributes.descriptio + " </td></tr>" +
        "<tr><td id='tblSubline2' colspan='2'><img src= " + graphic.attributes.image_url + "?t=" + new Date().getTime() + " /></td></tr>" +
        //Notice my little time stamp change to the url above
        "</table><hr>";
    function onLayerUpdateEnd(){
      //when the layer is refereshed if the popup has a selected feature then
      //force the popup to get the content again
      if(map.infoWindow.count > 0){
        var graphic = map.infoWindow.getSelectedFeature();
        map.infoWindow.setFeatures([graphic]);
    var HighwayCameras = new FeatureLayer("https://services.arcgis.com/DO4gTjwJVIJ7O9Ca/arcgis/rest/services/Camera_Location_VDOT/FeatureServer...", {
      mode: FeatureLayer.MODE_ONDEMAND,
      visible: true,
      opacity: .5,
      outFields: ["*"],
      infoTemplate: infoHighwayCameras,
      refreshInterval: 0.1
    legendLayers3.push({
      layer: HighwayCameras,
      title: 'Highway Cameras'
    HighwayCameras.on('update-end', onLayerUpdateEnd);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
jaykapalczynski
Honored Contributor
I put this code in and I get an error:  Uncaught SyntaxError: Unexpected token if
          return "<table>" +
                    "</table><hr>";
     visible: true,
     opacity: .5,
     outFields: ["*"],
jaykapalczynski
Honored Contributor
Think I got it...  function onLayerUpdateEnd(){     missing the { on the Function
Testin now
jaykapalczynski
Honored Contributor
Thats it....yes the image refreshed automatically.....GREAT....thanks for your help so very appreciated.
