Legend title based on variable needs to refresh too
2278
08-26-2014 09:05 AM
TracySchloss
Honored Contributor
I have a project that let's the user change which attribute field is used in the display.  It's based on the sample https://developers.arcgis.com/javascript/jssamples/renderer_dynamic_layer_change_attribute.html  For the legend, I'm creating it if it doesn't exist, but if it does, then I just want it to refresh.  My problem is that the title is based on a variable, defined based on the change event of the FilteringSelect list of fields.  When I change the field, the legend itself updates, but it still has the title from its initial creation.
Can I change just the title?  It doesn't seem to be honoring my title definition when I specify legend.refresh().  In this example, fields is the array of attributes from my layer and fieldChoice is the selected item from the FilteringSelect.
  domConstruct.empty("legendDiv");
        if (!legend){
         legend = new Legend({
            map: map,
            layerInfos: [{ "layer": featureLayer, "title": fields[fieldChoice] }]
          },"legendDiv");
          legend.startup();
          }else{
            legend.refresh();
Tags (1)
KellyHutchins
Esri Notable Contributor
If I understand the question correctly then calling legend.refresh and providing the updated layer info with the new title should update the title in the legend.
          legend.refresh([{
              layer: featureLayer,
              title: "Updated layer name"
MirceaMaierean
Ran in the same problem while creating a web map for my Capstone project but using the Generate Render Sample (Generate renderer | ArcGIS API for JavaScript )
I got to solve the problem by adding the "app." back into it and setting the "var app []" as a global variable.
function createLegend(map, fl) {
  // destroy previous legend, if present
  if ( app.hasOwnProperty("legend") ) {
app.legend.destroy();
  domConstruct.destroy(dojo.byId("legendDiv"));
  // create a new div for the legend
  var legendDiv = domConstruct.create("div", {
  }, dom.byId("legendWrapper"));
  app.legend = new Legend({
  map : map,
  layerInfos : [{
  layer : fl,
  title : "Census Attribute: " + fields[currentAttribute]
  }, legendDiv);
  app.legend.startup();
TracySchloss
Honored Contributor
That's not just changing the title, it's getting rid of the entire legend and recreating it every time. I'd like to avoid this.  What I did was add another div right above the legend, calling it legendTitle.  Then I styled the legend so that its default title wouldn't display at all.
.esriLegendServiceLabel {
   display:none;
Then I set the content of my new legendTitle to be the field name like I wanted.
KellyHutchins
          legend.refresh([{
TracySchloss
Honored Contributor
Your way worked and is more right then my workaround method, so I changed which one is marked as Correct Answer.
