Legend on web map, scripting error
850
03-19-2013 02:27 PM
ZacharyAguayo1
I'm working with Arc's API for a school project. I have put in a few widgets into my script. The only one I am having issues with is the legend/Toggle, I am unable to get the toggle to work. Can someone take a look at my script and let me know what I'm doing wrong. I've been at this for about a week and I just don't know what I'm doing wrong. I followed all the directions. Thank you,
var map, legendLayers = [];
function init() {
map = new esri.Map("map", {
basemap: "topo",
center: [-110.934448, 32.331238],
zoom: 10
//Legend starts here
var homicideLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://masgis2.asu.edu:6080/arcgis/rest/services/Group4/Riggs_Test/MapServer/0",{id:'Homicide'});
legendLayers.push({layer:homicideLayer,title:'Homicide'});
var rapeLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://masgis2.asu.edu:6080/arcgis/rest/services/Group4/Riggs_Test/MapServer/1",{id:'Rape'});
legendLayers.push({layer:rapeLayer,title:'Rape'});
var aggassaultLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://masgis2.asu.edu:6080/arcgis/rest/services/Group4/Riggs_Test/MapServer/3",{id:'Aggravated Assault'});
legendLayers.push({layer:aggassaultLayer,title:'Aggravated Assault'});
var robberyLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://masgis2.asu.edu:6080/arcgis/rest/services/Group4/Riggs_Test/MapServer/2",{id:'Robbery'});
legendLayers.push({layer:robberyLayer,title:'Robbery'});
dojo.connect(map,'onLayersAddResult',function(results){
var legend = new esri.dijit.Legend({
map:map,
layerInfos:legendLayers
},"legendDiv");
legend.startup();
map.addLayers([homicideLayer,rapeLayer,aggassaultLayer,robberyLayer]);
//add check boxes
dojo.forEach(legendLayers,function(layer){
var layerName = layer.title;
var checkBox = new dijit.form.CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function(evt) {
var clayer = map.getLayer(this.value);
clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
//add the check box and label to the toc
dojo.place(checkBox.domNode,dojo.byId("toggle"),"after");
var checkLabel = dojo.create('label',{'for':checkBox.name, innerHTML:layerName},checkBox.domNode,"after");
dojo.place("<br />",checkLabel,"after");
