Legend dijit support for Annotation layer
1763
5
05-13-2013 05:55 AM
NageshNangi
In version 3.4, Legend dijit is unable to generate legend when map service contains annotation layer. In older version 3.1, it was working fine. Is it a known issue?
PaulLeedham
Managed to resolve my issue by referencing the 3.5 version--I realize that this is not officially released but it did the trick for me.
ShreyasVakil
Hi Nagesh,
It is a know issue at v3.4. The legend dijit fails to load when making use of ArcGIS Dynamic Map Service with annotation layer. Unfortunately there is no workaround documented at this point.
Shreyas
PaulLeedham
I am also experiencing this issue.  It works fine in 3.3 but when targeting the 3.4 version of the API it crashes the legend  when attempting to load any map services with annotations.  I am also running 10.1 SP1.  Do you guys think you will have a work around for this or will you wait until 3.5 to resolve the issue?
PaulLeedham
NageshNangi
Thank you friends for confirming my doubt. Do you have any clue when 3.5 is releasing?
ShreyasVakil
It should be officially releasing soon (Maybe in a week or two). You can still reference the new api and get this to work. Just change the version number in your existing code to 3.5.
